is it okay to "T" your fpr hose twice?
im pretty sure it is okay, but im double checking, can i "T" off my wastegate and BOV into the same line which would be my fpr hose?
Re: is it okay to "T" your fpr hose twice? (PCdc2)
Try to use different vac lines for each of the items.
FPR should get it's own vac line
Wastegate should get it's own vac line.
Bov - you can Tee it off to something else.
It may be just me but i rather not tee of anything is really important to the motor.
people will offer different opinions on this, but both ways have worked
I teed everything off my fuel pressure line, blow off valve, wastegate, profec A, FPR, etc etc
HT's Biggest Loser
Re: is it okay to "T" your fpr hose twice? (trbob16a)
Im also a firm believer that each vacuum line should have its own port. If you look at my Intake Mani, i have 5 different vacuum ports. its "OK" to tee it off yer FPR line, but try to put it elsewhere if possible
Re: is it okay to "T" your fpr hose twice? (SIXTYdashONE)
the directions in the greddy instructions say to tee the greddy wastegate of the FPR line, that is going to make it work properly, i tried teeing it off another secondary and i pushed 15 pounds, im not wondering where to tee it, im just making sure it is okay to tee the line twice
it should be ok, but personally i dont like to t -off any line more than once. but to answer your question, yea, it should be ok as long as u dont go crazy with it
Re: is it okay to "T" your fpr hose twice? (Pengo)
ya, i need to move the t because im pushing 15 pounds right now and i have to drive to chicago for import revolution tomorrow and i dont wanna run that kind of boost down there. two t's on the fpr line is all there will be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PCdc2 »</TD></TR><TR><TD CLASS="quote">ya, i need to move the t because im pushing 15 pounds right now and i have to drive to chicago for import revolution tomorrow and i dont wanna run that kind of boost down there. two t's on the fpr line is all there will be</TD></TR></TABLE>
Are you showing or just going to look....
well most people have said it's fine to doulbe T the FPR. it states in the directions to T the wastegate of at the FPR hose. i currently have my wastegate T'd at the secondaries and my BOV is T'd into the FPR, the reason i was asking if i can T my BOV into the secondaries is because im considering just swapping the two.... which means T my BOV into the secondaries and my wastegate into the FPR would that be ok?
