Procedure for LS rods in a 1.6L sohc vtec
Old May 31, 2002 | 03:36 AM
Hybrid's Avatar
Default Procedure for LS rods in a 1.6L sohc vtec
Yes I did a search and I found nothing relevant.
Before I go ahead and get LS rods for my sohc vtec application what is the procedure for installing them? Like to do need grind any metal out of the way?
And what rods bearings can I use? I just picked up a new set for my stock rods. Can I use them?
Info please.
Old May 31, 2002 | 04:21 AM
DSF's Avatar
DSF
Default Re: Procedure for LS rods in a 1.6L sohc vtec (Hybrid)
The small end bore must be re-bushed for the smaller D-series pin and the big end width must be milled to accomadate the D-series crank's rod journals. Any machine shop should be able to do it for you. You'll use appropriatly sized (read: plastigauge) D-series bearings.
Mr. Self Destruct
Oct 13, 2005 09:32 AM
menkio
Nov 20, 2004 03:11 AM
Timmayeg
Dec 10, 2002 03:58 AM
sherman
Nov 28, 2002 02:04 PM
