Problema con b16a2
Hola a todos, tengo un problema en un b16a2, he montado un turbo y todo iba perfecto, pero me he dado cuenta que me sopla por el tapon del llenado del aceite, por el respiradero de la tapa de balancines y si quito la varrilla del nivel tambien por hay, he desmontado el turbo y lo sigue haciendo, de compresion esta bien, y la junta de la culata tambien, en relenti se queda como a tres cilindros, pero muy suabe........que puede ser? gracias
translator had a hard time with this one, here goes:
Hello to all, I have a problem in a b16a2, I have mounted an I disturb and all went perfect, but I have given myself account that blows me for the tapon of the filled of the oil, by the respiradero of the cover of balances and if I remove the varrilla of the level tambien by there is, I have dismantled the I disturb and continues it doing, of compresion this well, and the meeting of the culataremains as to three cylinders, but very suabe. .......que can be? thanks
http://www.freetranslation.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxadam »</TD></TR><TR><TD CLASS="quote">translator had a hard time with this one, here goes:
http://www.freetranslation.com/ </TD></TR></TABLE>
Way Off
Here"s my take:
Hi to everyone I'm having problems with my b16a2. I had put a turbo system and everything was fine but now I noticed air pressure(blow by?) coming off the oil cap, air breather and sometimes thru the dipstick... I have taken off the turbo and it still doing it. Compresion is fine and the head gasket is fine also. When in idle it feels as if only 3 cylinders were working.. very poorly, What could it be? thanks.
Do I get some price???
Way Off
Here"s my take:
Papi, Verifique sus bujias. Hizo usted una prueba de la compresion para ver si eso era lo que esta equivocado? Tambien usted se mejorara ayuda si usted puso en ingles. Pero hay amigos espanoles de aqui ayudarlo.
wtf?! i hope all of you realize this guy is joking, im sure he can read perfectly good english, other wise he wouldn't be able to navigate his way to make a post.
jeebus...
jeebus...
jdm96db8integra
May 26, 2010 01:30 PM
