Problem with wiring/tuning
Old May 12, 2002 | 07:15 PM
abraunb16's Avatar
New User
Default Problem with wiring/tuning
I swapped a fully built B18A with a turbo in my '99 Civic Si! I'm still using the Si harness. I've had some troubles with the AEM unit I purchased for my set up and I'm thinking that it might be due to the harness. The AEM is 99 Si specific. Here's a problem I encounter, I was getting the car up and running with the stock computer and things went fine, kinda. I was able to start the car and get it to idle. I proceed to get the AEM up in running, well I started with the programing, but couldn't get things going, so I called AEM and had to do a little data logging, then send the info to them(AEM). Well I got a response stating that the computer was looking for a crank sensor and since the first gen B18 doesn't have a crank sensor. So I had to swap some wires on the distributor, namely the TDC and CYP wires to get a reading off the cam(?). So I tried to get the P&P up and going again yesterday, but nothing. I'm having issue where I can't get spark now. So am I wasting my time with the harness? Should I get the LS specific harness? What if any wiring needs to be changed. I'm not a wiring genious so any help would be appreciated. Thanks in advance. Later Allen
Old May 12, 2002 | 08:41 PM
sgT's Avatar
sgT
Default Re: Problem with wiring/tuning (abraunb16)
The problem is in the ECU.
Apparently its looking for the CFK sensor, which a B18A wont have unless you
put one there. I know on the honda ecus that doesnt cause a problem.
You arent using a b18a distributor are you? If you are, a lot of the sensors are
different between the pre 92 distributors and post.
Old May 13, 2002 | 05:54 AM
abraunb16's Avatar
New User
Default Re: Problem with wiring/tuning (sgT)
No I'm using a 96 up LS Distributor. The crazy thing is the stock ECU will fire and idle/run the car. I just can't get the AEM to get spark, so it got me thinking that I might need to go through the hardness and repin it or check for potential problems. I also have a chance to get a last gen DFI, my thinking is I can hardwire it in(well have someone else hardwire it in) to avoid any of the problems. Let me know what you think. Thanks again for the help. Later Allen
99accattack
Oct 3, 2013 06:40 PM
jmh4bb6
Aug 28, 2013 11:15 PM
OLD_HATCH
Welding / Fabrication
Nov 29, 2007 10:23 AM
Maxximtl
Mar 15, 2006 02:39 PM
89 CRX SI
27
Jan 20, 2003 04:12 PM
