problem with over heating.
Old Apr 30, 2007 | 09:01 PM
young geezer's Avatar
Default problem with over heating.
well i have a gsr turbo with front mount intercooler and a after market alumimun FAL radiator. i]it over heats and i turn on the heater on blast and it slowly goes down. i was guessing the thermo or the water pump but dont want to start taking things out with out knowing wat the real problem. any inputs could help. thanks.
Old Apr 30, 2007 | 09:18 PM
da_dude's Avatar
I'll check what you have already mention. Does your radiator fan comes on? Check that and the coolant hose.
Old May 2, 2007 | 10:38 AM
Default Re: (turb20_vtec)
how do i check the radiator hose. check for cuts? i am about to switch out the thermo and waterpump after if thermo is not the problem.
Old May 2, 2007 | 10:47 AM
da_dude's Avatar
Default Re: (young geezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young geezer &raquo;</TD></TR><TR><TD CLASS="quote">how do i check the radiator hose. check for cuts? i am about to switch out the thermo and waterpump after if thermo is not the problem. </TD></TR></TABLE>
Make sure the hoses are good condition. Happen to my cousin car. We change everything we can think of and at the end it was a coolant hose that was leaking coolant small amount of coolant. Check for cuts, holes, anything that will cause a leak or air to escape. One little air leak or coolant can cause over heating.
Old May 2, 2007 | 10:48 AM
da_dude's Avatar
Could be a head gasket starting to go too. Does your car have white smoke from the exhaust?
Old May 2, 2007 | 10:50 AM
BDogggUT34's Avatar
Default Re: problem with over heating. (young geezer)
I had this problem, i changed my thermostat and problem solved I had the same symptoms, i had to turn on the heat for it to got back down. Thermostats arent that much so i would try that.
Old May 2, 2007 | 10:54 AM
White Smoke's Avatar
i my honda
Global Mod
Did it start happening after you installed you radiator? Did you bleed the system? 75% of the time thats the problem.
If you let the car run the fan should automatically come on. If its not coming on and the temp is going up then change the thermo switch.
Check those two first before riping everything apart.
efjones9
13
Aug 17, 2008 09:02 PM
streetsmart
Sep 3, 2007 01:16 PM
smokerz212
Jan 8, 2007 05:13 PM
h22 booster
Sep 5, 2006 06:40 AM
iani_2006
Dec 14, 2005 07:40 AM
