Problem!...No boost!...Help
Old Jul 4, 2004 | 07:54 AM
B18PoweredCivic's Avatar
Default Problem!...No boost!...Help
I made a custom kit and everything is installed right...except I dont have a downpipe...Jut a 8 inch long pipe so my exhaust blows straight down and not on my radiator...and I have no boost...car doesnt boost at all...I was missing the ring on the bottom of the wastegate so I custom made a a flange to fit there...and the wastegates not opening so it should be boosting.....I dunno what wrong...Could not having a down pipe cause no boost..I hear the turbo spooling but there no boost...Please help...any info would be greatly appreciated...thanks
Old Jul 4, 2004 | 09:30 AM
Default Re: Problem!...No boost!...Help (B18PoweredCivic)
any thoughts?
Old Jul 4, 2004 | 11:30 AM
gramentz's Avatar
check the charge pipes...could be a leak somewhere
Old Jul 4, 2004 | 11:59 AM
Charge pipes are all connected....Turbo is a new rebuild...and wastegate was missing the ring that sits between the wastegate and flange on top of the turbo manifold so I custom welded two washer together and tried that but still no boost...I have no downpipe either...Could that be the problem?...Could it be the turbo?
Old Jul 4, 2004 | 01:54 PM
up
Old Jul 4, 2004 | 04:15 PM
NVturbo's Avatar
O.G. triple O.G.
Check your upper piping (to throttle body) for leaks....BOV locations...vacuum lines....spark plug wires...Just double check because all these items can and will prevent you from boostin'....
Old Jul 4, 2004 | 06:27 PM
Ok...SO i took my turbo off and the edge of my exhaust housing is broken right along the edge of it....Could thi sbe causing no boost?...thanks
Old Jul 4, 2004 | 06:30 PM
Highrevs99's Avatar
Default Re: (B18PoweredCivic)
Yep, that would do it . Any exhaust leaks before turbine wheel will cause low or no boost .
Andrea
Mid-Atlantic (Sales)
18
Sep 11, 2007 06:35 AM
Andrea
Northeast (Sales)
20
Sep 11, 2007 06:34 AM
Andrea
Aug 29, 2007 04:43 AM
KeyserSoze
Welding / Fabrication
40
Nov 27, 2005 10:21 PM
Turbo_Teg
Jan 11, 2002 11:03 AM
