Problem with my Engine Damper!
Old Sep 19, 2006 | 05:35 PM
enigma94's Avatar
Default Problem with my Engine Damper!
I have a Fluidampr currently on my built GSR. But i'm going to be swapping to motor set up into a car with power steering. The problem is that the Fluidampr pulley doesnt have a extra belt slot for anything else beside the alternator. I emailed then directly but still no response...Does anybody know if they make one that allows you to use power steering? If not, does anybody know of a company that does?
TIA!!
Old Sep 21, 2006 | 02:21 PM
enigma94's Avatar
Default Re: Problem with my Engine Damper! (enigma94)
uppp
Old Sep 21, 2006 | 02:31 PM
non-VTEC's Avatar
obviously if there is no pully for the P/S belt then you cant run power steering......
switch to the stock crank pulley....
Old Sep 21, 2006 | 02:37 PM
Brain3208's Avatar
Default Re: Problem with my Engine Damper! (non-VTEC)
+1 I looked on google and a couple sites that sell them, could not find any pulley that will acomadate PS, looks like your gonna have to either ditch the pulley or the PS.
enigma94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">obviously if there is no pully for the P/S belt then you cant run power steering......
switch to the stock crank pulley....</TD></TR></TABLE>
Yes, I obviously knew that. My question is, does any other company make a damper that allows you to run power steering?
Old Sep 21, 2006 | 02:39 PM
enigma94's Avatar
Default Re: Problem with my Engine Damper! (Brain3208)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brain3208 &raquo;</TD></TR><TR><TD CLASS="quote">+1 I looked on google and a couple sites that sell them, could not find any pulley that will acomadate PS, looks like your gonna have to either ditch the pulley or the PS.</TD></TR></TABLE>
damnit.... I was afraid it was going to come down to that. I wonder which stock pully I should run, a LS or a GSR. Seeing that i have a LS crank i'm leaning towards a LS pulley. Or are they both the exact same?
Old Sep 21, 2006 | 05:20 PM
BB6-213's Avatar
I think fluidampr makes a "street" version that has p/s.
Old Sep 21, 2006 | 05:41 PM
gdh8su's Avatar
Default Re: (BB6-213)
Fluidampr part#590601. Street series Alt,PS, and AC. I think you can remove the AC pulley if not needed.
Old Sep 21, 2006 | 07:57 PM
V-SPEC 1's Avatar
Default Re: (gdh8su)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdh8su &raquo;</TD></TR><TR><TD CLASS="quote">Fluidampr part#590601. Street series Alt,PS, and AC. I think you can remove the AC pulley if not needed.</TD></TR></TABLE>
Old Sep 21, 2006 | 08:12 PM
dartdc97's Avatar
Default Re: (V-SPEC 1)
hey bro, check ATI's dampner. they sell quality dampners for the b-series with ps pulley
Old Sep 22, 2006 | 03:47 AM
enigma94's Avatar
OMG you are my hero!
Old Sep 22, 2006 | 04:23 AM
mike1114's Avatar
Default Re: (enigma94)
I have this one. Its great!! I don't run the PS though cause my hatch never had it.
Old Sep 22, 2006 | 07:25 AM
earl's Avatar
We sell the ATI dampners and the street version comes with a removable third pully that is used for powersteering
http://www.laskeyracing.com/shop/balancers.htm
Old Sep 22, 2006 | 09:21 AM
gdh8su's Avatar
Default Re: Problem with my Engine Damper! (earl)
Maybe it is the PS pulley that is removable. I only use the Alt anyway .
puffxy
Nov 11, 2004 01:00 AM
Pete_SI
Apr 15, 2004 06:58 PM
EL-Driver
Aug 3, 2003 07:27 PM
