Is this a problem, Looks like white smoke :(
Old Sep 7, 2004 | 06:23 AM
Mr.DC2TurBo's Avatar
Default Is this a problem, Looks like white smoke :(
Info on the car: Turbo LS with internals done (pistons, rods, block guard) and GUTTED CAT with 2.75 inch exhaust pipe.
Ok, I asked my mechanic awhile back about the white smoke and he said it was just an increase in the carbon monoxide fumes from the gutted cat and that there was nothing to be worried about.
I don't see a puff or a cloud of smoke while I'm drive (when I look in the rear view mirror) but when I do park in my garage I notice white (maybe grey) smoke gradually filling the room up. I checked the coolant and the levels are normal. No smoke is coming from the engine. When I first start the car there is no smoke but the longer the car idles, the smoke will start to appear. So am I just being paranoid bc the car drives great?
Modified by Mr.DC2TurBo at 9:37 AM 9/7/2004
Old Sep 7, 2004 | 06:27 AM
Ckjeepin's Avatar
Default Re: Is this a problem, Looks like white smoke :( (Mr.DC2TurBo)
If your cat is gutted or you dont have one. It will smoke more..
When i removed the car on my srt it made more smoke... But it was a light blue / white.
Old Sep 7, 2004 | 06:28 AM
finah's Avatar
overheating at all? possibly a HG
Old Sep 7, 2004 | 06:33 AM
Default Re: Is this a problem, Looks like white smoke :( (bdt09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdt09 &raquo;</TD></TR><TR><TD CLASS="quote">overheating at all? possibly a HG</TD></TR></TABLE>
no overheating issues. what is HG?
Old Sep 7, 2004 | 06:36 AM
finah's Avatar
headgasket
Old Sep 7, 2004 | 06:38 AM
if it was the headgasket, wouldn't my coolant levels be low?
Old Sep 7, 2004 | 06:50 AM
finah's Avatar
other people hav had this problem i think someone said it was the valve seals, do you see anything leaking visibly? check the plugs, oil and do a compression/leakdown test
Old Sep 7, 2004 | 07:16 AM
Default Re: (bdt09)
No leaks that I can see and no oil leaks either.
Old Sep 7, 2004 | 08:23 AM
djwest24's Avatar
Default Re: (Mr.DC2TurBo)
does the smoke smell like coolant??? if it doesnt, it could be just wht ur mechanic said....mine does it too...
Old Sep 7, 2004 | 08:32 AM
Default Re: (quicksilver17981)
no coolant smell just fumes
Old Sep 7, 2004 | 08:47 AM
chad174's Avatar
Running rich will tend to do the same thing, I think. My car does the samebut it is running very rich right now. I recently changed the headgasket, using lots of copper spray, and nothing changed. I had a valvejob done withnew seals, And I am wondering if the seals could be bad. What are good indications? Burns some blue smoke if I romp first and second prettyhard, but compressionand leakdown on my motor is well within spec.
Old Sep 7, 2004 | 08:56 AM
Default Re: (chad174)
I might be running rich too. I haven't got my car tuned yet and I can see water like particles in the inside of my exhaust.
thedon360
Jul 16, 2013 08:34 AM
dailyekhatch
Aug 15, 2011 06:45 AM
Mfoehrkolb
Oct 21, 2007 12:05 AM
Boring
17
May 9, 2005 09:09 AM
EK Josh
Jan 2, 2005 11:14 PM
