Problem found, look at my AVC-R!
Old Apr 12, 2004 | 11:44 PM
superfuji57's Avatar
Default Problem found, look at my AVC-R!
So after hours and hours of re-wiring, soldering, and testing, I finally took apart the head unit, and this is what I found....
It's kinda hard to tell, but there's a gash right there on the board, and the copper has been scraped off. WTF!!???! I bought this brand new in the box.
Anyway, does anyone know how I could maybe get rid of this one and get a new one? I appreciate any help, and those who have already hleped me.
Old Apr 13, 2004 | 12:13 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Problem found, look at my AVC-R! (superfuji57)
put it back together, and tell them they sold you crap? lol
Old Apr 13, 2004 | 12:37 AM
Smokinsax's Avatar
The Boot
^^^seriously...thats a good idea!
Old Apr 13, 2004 | 12:52 AM
I got it off ebay =\ around 9 months ago. I don't have a receipt or anything, it's been lying around until it finally came time to put it in. Am I just **** outta luck???
Old Apr 13, 2004 | 12:54 AM
ImAcracker's Avatar
Loved
You could always find the broken traces and connect them via some wires and solder. Or if the gash is real close you might get away with just some solder.
Old Apr 13, 2004 | 05:52 AM
00b18b's Avatar
Default Re: (superfuji57)
buy a brand new one, throw the old one back in the box and return it
Old Apr 13, 2004 | 06:39 AM
allmotorteg_96's Avatar
Default Re: (00b18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b18b &raquo;</TD></TR><TR><TD CLASS="quote">buy a brand new one, throw the old one back in the box and return it </TD></TR></TABLE>
Old Apr 13, 2004 | 10:16 PM
It's not like you can just buy these things at wal mart =\. I called Apex today and they pretty much said I'm **** outta look.
Old Apr 13, 2004 | 10:32 PM
lonnieboost's Avatar
That s what you get from ebay.
Old Apr 13, 2004 | 10:46 PM
Silverbeast's Avatar
That is the reason that gray market stuff, both apexi and greddy suck. There is absolutley nothing you can do about it and overall it just hurts legit buisnesses.
Old Apr 13, 2004 | 10:48 PM
Devlins 91LS's Avatar
Default Re: (lonnieboost)
fix it
Old Apr 13, 2004 | 11:43 PM
1fstevo's Avatar
New User
I don't think any shops function like Walmart....
Old Apr 14, 2004 | 01:08 AM
simple4012's Avatar
New User
Default Re: Problem found, look at my AVC-R! (Silverbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast &raquo;</TD></TR><TR><TD CLASS="quote">That is the reason that gray market stuff, both apexi and greddy suck. There is absolutley nothing you can do about it and overall it just hurts legit buisnesses.
i disagree. 100%
try to see where it was going and make the connection yourself with solder and wire. you can do it, its not hard
Old Apr 14, 2004 | 01:52 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Problem found, look at my AVC-R! (simple4012)
easy fix as most poeople have said.
Old Apr 14, 2004 | 01:53 AM
Vtec92Civic's Avatar
get a loan or borrow $$ from someone, but another AVCR and just return the broken one right away for a refund or something. I'm sure you got a credit card.
Old Apr 14, 2004 | 01:55 AM
hondaboii's Avatar
Try to get a better picture...its hard to see how many broken traces you have.
If your going to attempt to fix it...here is what you might want to do.
You will need these tools:
-solder iron
-flux (for cleaner joints)
-lead
-tooth brush
-alcohol (99%)
-dentist tools (something pointy that you can scratch the board)
-thin wires (if ever needed use like 24ga or really THIN)
-analoge/digital tester
here are the steps...
1) get an old tooth brush, and isproylene (sp?) alcohol (99%) and put that on the brush and brush the board and let it dry, basically cleaning it first.
2) try to figure out which traces were broken (important to do one joint at a time so you wont lose track)
3) scratch the board so you can see the copper traces
4) with your hot iron, put some lead on the tip and put a little lead on the scratch part of the board.
5) using the thin wire, (its better that the wire has insulation so there wont be any electrical shorting) strip a small peice at each end and put some lead on the wire.
6) then again with the hot iron, you put the iron on the board and then connect one side of the wire on the board.
7) do the same for the other side.
8) clean it again with the alcohol and let it dry.
use the flux when your soldering on the board, you put the flux first then you solder, this way the melted lead wont go to the other joints causing a short.
Use the digital/analoge meter to find out where the connection is suppose to go. Always double check before your going to solder anything...
Well, I hope this helps...if not, im sorry to have wasted your time. Good luck!
Old Apr 14, 2004 | 04:36 AM
ScrapinSi's Avatar
if you dont want to fix it, sell it to me for cheap!
Old Apr 14, 2004 | 07:14 AM
Joseph Davis's Avatar
Default Re: Problem found, look at my AVC-R! (ScrapinSi)
Sup.
I'm the assmallet on AIM made you open the AVC-R and take a picture for me. I'll repair it for you if you feel uncomfortable.
AMS MIKE
Apr 12, 2011 08:07 AM
upgrayedd
Sep 26, 2010 07:34 PM
IceySC
Southeast (Sales)
Jul 3, 2007 08:03 PM
