problem with eagle rods (not a honda)
Old Aug 10, 2012 | 09:28 PM
wantboost's Avatar
Who is Mr Robot?
Default problem with eagle rods (not a honda)
I have a vg30dett that I'm currently in the middle of rebuilding. Bottom end has eagle rods and JE pistons. When I pulled the pistons off of the rods 3 of the small end rod bushings showed signs of cracking bit only along the very bottom section of the bushing between the two oiling holes. I will have pictures as soon as I charge my.phone
That last one is the worst
My question is what would cause something like this to happen? Motor showed no signs of an oiling issues or any sort of bottom end damage. Can these rods be sent to eagle an
d have new bushings pressed in?
Old Aug 10, 2012 | 11:29 PM
rich7777's Avatar
Default Re: problem with eagle rods (not a honda)
Any reputable machine shop should be able to replace them without a issue. Call up your machine shop and see what they say. I don't think they're hard to change...
Old Aug 11, 2012 | 12:01 AM
wantboost's Avatar
Who is Mr Robot?
I'd rather have Eagle do it.since it's their product and they know the proper small.end diameter
Old Aug 12, 2012 | 02:57 AM
wantboost's Avatar
Who is Mr Robot?
no idea on what caused this?
Old Aug 12, 2012 | 04:43 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
How much past the factory rev limit are you pushing it? Also, Eagles are cheap for a reason.
Old Aug 12, 2012 | 12:43 PM
wantboost's Avatar
Who is Mr Robot?
I haven't used this motor.. got it with the internals but I know it was on a stock limiter
Bobnotch
Nov 26, 2017 09:45 AM
turbodcxbro
Jun 29, 2011 10:20 AM
ARACER25
Jul 10, 2006 06:58 PM
TheSwift1
Oct 26, 2002 09:27 PM
