Problem after installing twin disc - Help!!
Old Aug 5, 2010 | 06:46 PM
gizzmo222's Avatar
Default Problem after installing twin disc - Help!!
I recently installed a twin disc into my car and now that it is all back together the car won't start..
I replaced the starter, fuse box, ground wires, took the nuetral safety switch completly out and it still won't start.
The car is acting as if it had the nuetral safety switch still was enabled in the car. I turn the key and nothing happens, no clicking from the starter or anything.
Any suggestions? And I understand that this isn't really the right section but I feel the more intelligent people are in the Forced Induction section!!
Thanks!!
Old Aug 5, 2010 | 07:15 PM
BlakeJ53's Avatar
Default Re: Problem after installing twin disc - Help!!
So the car does not crank at all?
Old Aug 5, 2010 | 07:21 PM
gizzmo222's Avatar
Not at all, the battery is good. Not even a peep from the starter though. But the fuse box did seem to make a lot of noise but i swapped it for another one and it did the same thing..
Old Aug 5, 2010 | 07:51 PM
cpl rampage's Avatar
trace the starter signal wire back through the components, first make sure it puts out 12 volts when u crank, then follow it to the relay etc. grab a wiring diagram and trace it out with a volt meter
as long as the grounds are on, and you didn't pinch any wires while installing it, i don't know what it could be. what neutral switch are you talking about?
Old Aug 5, 2010 | 08:54 PM
2_onelsvturbo's Avatar
check your tranny ground!!!
MyHotsh
50
Apr 21, 2010 03:30 PM
big-cat
Apr 22, 2008 02:19 PM
altoid
Nov 25, 2007 03:10 PM
CRX7
Aug 29, 2005 01:42 PM
DsCivicEx
Jan 23, 2004 05:44 PM
