precision sc61
Old Mar 3, 2006 | 07:32 PM
high boosted rex's Avatar
Default precision sc61
i have searched, just wondering whats the most power some people have made from the sc61?? 500-600whp capable on a built gsr??
Old Mar 3, 2006 | 08:04 PM
s2kdre's Avatar
Default Re: precision sc61 (high boosted rex)
2.0L gsr with a 84.5mm bore i've seen 579whp on 28psi. the turbo stopped makin power. but im sure u can make over 600
Old Mar 4, 2006 | 12:09 AM
airshifter's Avatar
84 bore ls/vtec made 550 at 24 lbs with gsr cams, ran out of boost controller with the 10 lb spring or I would have taken it higher
Old Mar 4, 2006 | 08:00 AM
Fkned's Avatar
James Innes/John ferguson made 620 something a few years back w/an sc61 and aftermarket cams for the intake on their 2 ltr.
ihaterice's Avatar
Default Re: (airshifter)
just for another reference
not the SC61
but innovative t3 gt61s (same size)
85mm bore
9.0:1 compression
stock gsr crank
636 at 34 psi
so definately have some potent hp potentially with that size turbocharger
one of the best all around for a street car imo
Old Mar 4, 2006 | 09:05 AM
siblues's Avatar
Default Re: (ihaterice)
https://honda-tech.com/zerothread?id=1202180
Here is a nice example
Old Mar 4, 2006 | 09:07 AM
Muckman's Avatar
Moderator in Chief
Default Re: (siblues)
What are the wheel sizes of the SC61?
Old Mar 4, 2006 | 11:10 AM
lalspeed's Avatar
Default Re: (Muckman)
the torque seems to fall of pretty bad considering when it hits boost. atleast on the high boost chart. but imo its a good proven turbo thats been out for a while.
Old Mar 4, 2006 | 01:36 PM
Adriano's Avatar
Default Re: (lalspeed)
I have dynoed 486whp @ 22lbs using hondata. Now I'm using AEM and went 11.0 @ 128 at 22lbs on a 2550lbs car but never dynoed the car. I will be upping the boost to 28-29lbs next month.
Adrinao
Old Mar 4, 2006 | 07:29 PM
swapit's Avatar
Default Re: (Adriano)
ive made 600whp at 28.5lbs,on a 84.5mm b16 and their was still a couple pounds left so jeff evans said.maybe 31 to 32lbs and couldnt turn it up because the map senser was maxed out and the 255 intank was cryin for help.
Old Mar 4, 2006 | 08:36 PM
i want a civic's Avatar
Bump for some more numbers thinking about this charger for my setup...
Old Mar 4, 2006 | 09:46 PM
thanx for the input, i think this is the one i'm going with
legend97
Oct 21, 2013 11:51 AM
JM Performance
Oct 8, 2010 02:04 PM
sh!ft
Feb 1, 2010 07:09 PM
blackEK2.0
Jan 5, 2010 08:45 PM
blackeg
Aug 6, 2008 10:47 AM
