Precision Injector Install Issues Need Help!
Old Jan 11, 2010 | 07:16 PM
ESP.net's Avatar
Default Precision Injector Install Issues Need Help!
I am having a brain fart probably... I went to installed the 580cc Low Impedance Injectors Ball and Seat that I purchased into a OBD1 Prelude H22 Manifold...
However I cannot get the injector in all the way seems to bottom out
1st is the OEM plasic seal in the intake manifold
2nd is the OEM rubber seal
The O ring either on the Precision injector is being either too stuburn or too big. There is also a black spacer that seems to stop the O ring from going any further up... but I think its stoping it from seating...? do I use the OEM plastic bottom seal and rubber seal? Any help would be great...
OEM rubber seal is already on the Precision injector...
Old Jan 11, 2010 | 07:29 PM
ESP.net's Avatar
Default Re: Precision Injector Install Issues Need Help!
I think I figured it out... Brown O ring gets tossed!
Old Jan 12, 2010 | 08:09 AM
90blackcrx's Avatar
The o-ring should be used.
Old Jan 12, 2010 | 06:22 PM
ESP.net's Avatar
For the life of me couldnt get the injector to sit down with the O ring, took it out and it went in, kept the black spacer as the guide.
Used OEM plastic seal and rubber seal on each.
turbohatch96y7
Jun 14, 2012 08:34 PM
GarageAlchemist
Jan 10, 2007 10:46 PM
midwesta
15
Jul 14, 2005 05:35 PM
maxspeedhonda
Aug 27, 2004 12:06 PM
stupidfast
Aug 27, 2003 06:31 AM
