pre-boost check
Old Mar 26, 2006 | 11:25 PM
Rubixcu7's Avatar
Default pre-boost check
im planning on boosting my d16y8 and it has 144k miles. i want to to a compresson check on the motor to make sure all cylenders are still good so to say. it does run strong but i wanna make sure u know?
so how would i go about doing a compression check? i have a air comressor but what else would i need? any imput is greatly appreciated
-Rubix-
Old Mar 26, 2006 | 11:39 PM
komat's Avatar
Default Re: pre-boost check (Rubixcu7)
compression test wont require an air comporessor
but if you doing a leak down test you will
when you do the compression test
if hte numbers are 20- + psi from each other . then you are set to go
Old Mar 28, 2006 | 12:07 AM
Rubixcu7's Avatar
how do u do a compression check though... thats really what i was getting at
Old Mar 28, 2006 | 01:03 AM
EK k kay's Avatar
Buy a kit for like $10-$20 and then search for a write up.
nekoabandoned
Dec 8, 2005 05:43 AM
Suck my DX
Aug 26, 2005 11:05 AM
psycheus
Oct 21, 2004 02:44 PM
