Posting
When would posting be needed? On an N/A engine with out sleeves? Would a sleeved FI engine benefit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endyn »</TD></TR><TR><TD CLASS="quote">The posting process involves machining and tapping holes in the thrust sides of the block and torquing in threaded aluminum posts that physically connect the outer part of the cylinder with the outside (peripheral) walls of the block. With these posts installed, if the cylinder walls are going to move, they have to move the outside walls of the block too, so they add a tremendous amount of strength, making the block capable of withstanding a lot of abuse. This modification also has no ill effect on cylinder cooling.</TD></TR></TABLE> http://www.homemadeturbo.com/t....html http://www.muller.net/sonny/crx/engine/posted.html
Modified by slashDEVslashNULL at 2:05 PM 12/8/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra »</TD></TR><TR><TD CLASS="quote">don't do it, it creates hot spots, earl and FFgeoff can explain to u more on that.</TD></TR></TABLE>
Really? I was just toying with the idea for a junkyard block, to add a bit of strength. I am not about to drill and tap my non junkyard block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL »</TD></TR><TR><TD CLASS="quote">
If its a junkyard block its worth a try
</TD></TR></TABLE>If its a junkyard block its worth a try
guy_from_nerk
Jul 28, 2013 12:25 PM
lukehowell88
Oct 1, 2007 12:20 PM
