Post your vacuum line setups
Old May 18, 2006 | 12:36 AM
srg's Avatar
srg
Default Post your vacuum line setups
Please post pictures of your vacuum lines...
Old May 18, 2006 | 12:47 AM
Outkast95LS's Avatar
Default Re: Post your vacuum line setups (srg)
Using the GE vacuum manifold:
used to have a bunch of T's
Old May 18, 2006 | 12:57 AM
1158's Avatar
Default Re: Post your vacuum line setups (Outkast95LS)
Outkast, I know it's off topic, but do you have any more pics of your dump setup?
Old May 18, 2006 | 01:12 AM
Default Re: Post your vacuum line setups (1158)
I do.
There you go.
Old May 18, 2006 | 01:35 AM
srg's Avatar
srg
Do you have close-up pictures of your WG vaccum lines...?
I like your dump tube placement
Old May 18, 2006 | 03:41 AM
wade's Avatar
woah
Old May 18, 2006 | 04:06 AM
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast95LS &raquo;</TD></TR><TR><TD CLASS="quote">Using the GE vacuum manifold:
used to have a bunch of T's </TD></TR></TABLE>
any particular reason you made the dumptube that way? i would think it would give off quite a bit of radiant heat in the engine bay
Old May 18, 2006 | 05:52 AM
Hyaboosta's Avatar
Default Re: Post your vacuum line setups (drumking15)
GE Vac. Mani FTW! Makes everything alot easier and cleaner
Old May 18, 2006 | 05:56 AM
Turbo-charged's Avatar
Default Re: Post your vacuum line setups (Hyaboosta)
Old May 18, 2006 | 06:14 AM
srg's Avatar
srg
Default Re: Post your vacuum line setups (Turbo-charged)
wow! Thats clean
Old May 18, 2006 | 10:22 AM
srg's Avatar
srg
bump for more vacuum lines
Old May 18, 2006 | 10:26 AM
EJ1 wilcox's Avatar
Default Re: (srg)
Holy endtanks!!
I made a vacuum manifold myself from parts I bought at home depot. Worked excellent and only cost a few bucks. I'll see if I can find some pics.
Old May 18, 2006 | 10:27 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
that pic does no justice. looks great in person. cant wait for this weekend!
id post a pic of my eingine, but since it is a victor x manifold, and there like 10 fittings on the back of it, they are all hidden back there.
Old May 18, 2006 | 11:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">any particular reason you made the dumptube that way? i would think it would give off quite a bit of radiant heat in the engine bay</TD></TR></TABLE>
No particular reason.. i bought the kit and the dumptube was made that way. Also, not much radiant heat is given off. By the time i shut off the car and wait like 5 mins, the dumptube is cool enough to touch.
Old May 18, 2006 | 12:15 PM
fieldafm's Avatar
that looks really nice Joe... what size an do you have coming off the primary vacuum port from the G/E to your I/M? if you dont mind me asking... i have all -3 stuff going into the g/e manifold, but still have the very un-bling rubber hose feeding the g/e-i/m connection that i want to convert to a braided line to make sure everything is secure and connections are good
Old May 19, 2006 | 03:59 AM
Default Re: Post your vacuum line setups (fieldafm)
thanks man. honeslty i dont remember on the line feeding the vaccume block, im pretty sure i used a -8.
Old May 19, 2006 | 04:12 AM
Dee's Avatar
Dee
-4 AVC-R solenoid line and -6 w/g line
The blue vaccum manifold sitting on the fuel rail was moved to the back of the block.
Old May 19, 2006 | 04:49 AM
tepid1's Avatar
GE vac manifold behind the firewall on my 00 GSR
TDogg Teg
Jan 9, 2010 03:08 AM
Kaspk
Apr 6, 2007 03:12 PM
.David
Jun 8, 2004 01:10 PM
xci_ed6
Aug 10, 2002 05:35 PM
