Post ur *Average* dyno #'s.
Old Sep 30, 2002 | 05:33 PM
DIRep972's Avatar
Smarter than you
Default Post ur *Average* dyno #'s.
I got an idea for a post like this earlier after seeing an article about peak hp #'s vs. real life acceleration.
ill start with my car.
set up- Revhard kit w/ hondata on an LS motor.
My powerband is from 5300-7500 when racing. That is shifting at 7500 and having the RPMs fall down to 5300(LS tranny) and then shifting again at 7500 and so on. SO i picked 6 points(in my racing powerband) on the graph and averaged the hp. I figure this should give a rough estimation of how my car accelerates vs. another 275whp(peak) car.
<U>RPM</U> <U>WHP</U>
5300 237
5700 249
6100 270
6500 274
7100 265
7500 249
so the avg. whp for my powerband is 257whp.
who wants to go next?
[Modified by DIRep972, 5:42 AM 10/1/2002]
Old Sep 30, 2002 | 05:37 PM
dustin's Avatar
Default Re: Post ur *Average* dyno #'s. (DIRep972)
Torque would be a better thing to average than horsepower.
Old Sep 30, 2002 | 05:40 PM
DIRep972's Avatar
Smarter than you
Default Re: Post ur *Average* dyno #'s. (dustin)
its the same thing. just multiply the hp by 5250 and divide it by RPM. either way, it still tells u the same thing.
Old Sep 30, 2002 | 05:43 PM
dustin's Avatar
Hehe, but the "Area under the curve" of a horsepower graph is practically useless. Torque at the wheels is what determines how your car accelerates. I know I can extrapolate the values from your list, but no -- average horsepower and average torque are very different things.
Old Sep 30, 2002 | 05:45 PM
DIRep972's Avatar
Smarter than you
you missed that im not averaging area under the curve. I am avg. the curve itself.
Old Sep 30, 2002 | 05:50 PM
dustin's Avatar
Understand that numeric integration across that rev range with X partitions will tell you the area under the curve. Dividing this number by the number of partitions (X) will yield average value.
Old Sep 30, 2002 | 06:10 PM
racerxadam's Avatar
gotta love calculus. and i believe it is multiply by rmp and divide by 5252 not the other way around
Old Sep 30, 2002 | 06:16 PM
DIRep972's Avatar
Smarter than you
I see what ur saying. When I think of the phrase "area under the curve" I think of "power below turbo" but when you say area under the curve you mean the avg. power between two points.
I would like to discuss more about how hp vs. torque effect acceleration. I take back my first statement where I said hp and torque tell you the same thing. because they dont.
Hp is more useful in figuring out how fast a car accelerates then torque! what is hp? torque over a given period of time right? torque is only a measure of force and by itself will only tell u how much force is being put on an object, in our case to make it rotate. 200ft/bs of torque on an object 4 times per seconed will result in slower rotation of the object then 200ft/lbs of torque 8 times per seconed. So without factoring in RPM's(rotations per minute) you cannot figure out acceleration. torque by itself is useless.
edited it to make it sound better hehe.
[Modified by DIRep972, 3:35 AM 10/1/2002]
DIRep972's Avatar
Smarter than you
Default Re: Post ur *Average* dyno #'s. (racerxadam)
I was finding torque from hp, the opposite from normal.
Old Sep 30, 2002 | 06:23 PM
racerxadam's Avatar
sorry missed that
Old Sep 30, 2002 | 06:58 PM
TurboInteg95's Avatar
whoa, area under the curve.......... brings back chilling memories of my high school Calc 2 class.
Old Sep 30, 2002 | 07:14 PM
Ri5e's Avatar
Default Re: Post ur *Average* dyno #'s. (TurboInteg95)
Right on Direp!
Old Sep 30, 2002 | 08:19 PM
Stag 2000's Avatar
Default Re: Post ur *Average* dyno #'s. (4 Stroke)
mine
6800-295whp
7200-310whp
7600-325whp
8000-334whp
8300-334whp
avg.=319.6whp
I'm on my roommates screenname
Hybrid901
Old Sep 30, 2002 | 08:35 PM
Ri5e's Avatar
Default Re: Post ur *Average* dyno #'s. (Stag 2000)
5000 - 230whp
5400- 230whp
5800- 235whp
6200- 235whp
6600- 232whp
6800-225whp
231.16 avg. whp from 5000-6800
B20 STOCK @ 7-8 PSI / S-AFC/440/Vortech 8:1 FMU (My Old Setup)
Old Sep 30, 2002 | 08:37 PM
degradated's Avatar
New User
Dustin,
You're a smart guy, but Chris' explanation makes more sense to me and seems to follow my line of reasoning. Torque is definitely important, but like he said, it alone doesn't tell you anything until examine at what speed of rotation it's at, and by that point you have pure horsepower. Knowing that the car has 250 ftlbs of torque, let's say, is neat but not knowing where it falls on the curve is pretty useless. Say it falls at 2500 rpm, but drops off to 150 ftlbs by 5000. If you didn't know any better, you might think the car would begin accelerating slower as time went on, but in fact it's just the opposite. It's developing 119 hp at the first point and 142 hp at the 2nd mark.
Take the same torque numbers and shift them up by 2000 rpm each, and you now have a car that's making 214 hp and 200 hp. I guarantee the second car will out accelerate the first.
Damn, did I get off track? I think you were making a different point and I'm sure you knew this already, but maybe you can help clarify what you meant in your earlier post.
Old Sep 30, 2002 | 08:54 PM
dustin's Avatar
Default Re: Post ur *Average* dyno #'s. (degradated)
He's already stated that he is averaging Horsepower in the RPM band where he is racing, so RPM does not matter at all. Within that RPM range, his car will accelerate EXACTLY as his torque curve dictates.
Where you make torque is important because you can use gearing to your advantage -- This is why high redlines allow cars to accelerate faster (if they make torque in high rpms) because they do not lose effective torque to the wheels by shifting to the next gear as early.
However, he already took RPM out of the equation...
Take two vehicles. RPM and horsepower aside... at any given point the vehicle with more torque will have more instantaneous acceleration and will be (inherently) accelerating faster. F=MA.
This is only true if we are measuring effective torque at the wheels... This means we cannot use crank torque numbers corrected for drivetrain losses.... To estimate the outcome of a 2 vehicle race, we must know final drive as well as ratios for each gear. This is why simulators such as cartest require to enter all of this information.
If you would like a more concrete comparison, the easiest way is to attempt to graph effective torque at the wheels for a typical 1/4 mile run for our vehicle. Using the 1st gear ratio and final drive along with the dyno chart, graph ACTUAL torque at the wheels in first gear. "Shift" into second and do the same for all subsequent gears... graphing wheel torque. Do the same for the second vehicle. The car with more area under the curve wins the race. Note that you'll have to do some mathematical magic to discen how far 1/4 mile is, but you shouldn't have too much trouble This is what a gtech does and what cartest does mathematically.
Dustin
Old Sep 30, 2002 | 09:46 PM
DIRep972's Avatar
Smarter than you
alright, lets take RPM and hp out of the equation. take a look at these two graphs.
this one is an LS turbo @ 7psi of boost. (sorry its big, friend scanned it that way and im too lazy to fix it.) http://visualxposure.net/7lbs.jpg (made it a link just for u b20c5 turbo)
and this one is a GSR turbo @ 7psi of boost.
(dont let the uneven torque and hp axis's confuse u when looking at this graph. torque is on the right)
http://us.f1.yahoofs.com/users/e081b...__hr_dynoi.jpg ok i dont know what happened to the graph, all of a sudden yahoo says we dont have access. I guess u will just have to trust me on the tq values.
now compare the powerbands of the two cars. 5-7k for the LS and 6-8k for the GSR. put RPM aside and I will just pick 7 points of tq. for each car in the RPM band each uses for racing.
LS GSR
180 180
188 181
185 180
185 179
182 178
175 176
165 172
avg. tq for LS is 180ft/lbs. avg. tq. for GSR is 178ft/lbs.
the amount of torque each car is making is very similar and from what u stated above, these cars should be accelerating at very much the same pace. I have a feeling the GSR is gonna win the race not because it doesnt have to shift as early, but because it is putting out more torque per seconed then the LS. and tq per seconed, is hp(in general terms). also, lets assume both cars are running the same transmission so that will be a constant between the two set ups.
[Modified by DIRep972, 4:11 PM 10/1/2002]
Old Sep 30, 2002 | 10:21 PM
DIRep972's Avatar
Smarter than you
Dustin
maybe ill try that tomorow if i can find time.
Old Sep 30, 2002 | 11:07 PM
lazerus's Avatar
GEO Storm GSI W/ Impulse RS Engine, Stock rods/crank Arias custom pistons portwork, stock valvetrain Stock rods T3/T04e Turbo 18 PSI Boost (low boost) and rough tuning (Haltech), AFR's were in the 10-11:1 ratios and had misfires ~6k and valve float problems at above 8k.
New valve springs have been fitted, MSD DIS4HO, and more dyno time has solved the problems Power at 18 psi is near 390 hp and Power at 28 psi is unkown due we can't get traction on rollers! power is estimated to be 500+ to the ground.
Old Sep 30, 2002 | 11:14 PM
VaporTrail's Avatar
New User
torque is what the motor is actually producing. HP is acceleration. They are similar, but not the same.
Old Oct 1, 2002 | 12:34 AM
B20C5 Turbo's Avatar
New User
Dustin: You're a mart futher smucker and I would side with you, but:
I absolutely agree that the vehicle with more torque will have more instantaneous acceleration, as long as both vehicles have the same mass and both vehicles have the same overall gear ratio. (newtonsApple == newtonsApple)
The problem with your argument is that the "Force" variable in your equation is measured in Newtons, Kilowatts, Horsepower, ETC..., which includes time and distance and can easily be manipulated into one equation: (HP = RPM * torque / 5252). From that we can easily see that: torque * RPM / 5252 = mass * acceleration. This of course proves you to be half right. Torque is very important, but so is RPM. HP (read work done) is nothing without either one.
Fortunately most of the Honda vs. Chevrolet (or Ford, or Dodge, or ...) battles that I have fought stand to prove that half the torque at twice the RPM still equals victory for the lighter car. So the straight line race still goes to man with the most HP per lb (given identical drivers, traction, and mass...).
Vapor: Torque (ability to do work) ultimately leads to acceleration. HP is a measurement of torque over time (work done).
I would ultimately choose the car that makes the most torque at the highest RPM and has the best gear ratio(s) to use it.
Gear ratio is extremely important, but I do not have time to discuss that right now. G'night.
EDIT: DIYRep.. If you EVER post a graphic that big again, I will personally drive down to "The Lone Star State" and bitch slap you into the "Twin Star State" myself. [mumbling] "Too lazy to fix it..."... my ***.... mumble, something, mumble
[Modified by B20C5 Turbo, 2:58 AM 10/1/2002]
Old Oct 1, 2002 | 07:33 AM
dustin's Avatar
Default Re: Post ur *Average* dyno #'s. (B20C5 Turbo)
Dustin: You're a mart futher smucker and I would side with you, but: Take two vehicles. RPM and horsepower aside... at any given point the vehicle with more torque will have more instantaneous acceleration and will be (inherently) accelerating faster. F=MA. I absolutely agree that the vehicle with more torque will have more instantaneous acceleration, as long as both vehicles have the same mass and both vehicles have the same overall gear ratio. (newtonsApple == newtonsApple)
Hehe, we're saying the exact same thing. My argument is that "Average horsepower" across an RPM range is pretty useless because you get to pick the RPM. As far as I am concerned, Horsepower graphs are useless. Torque graphs are useful, and peak horsepower can give you an idea of where the vehicle makes torque... but Horsepower graphs are just pretty pictures.
Old Oct 1, 2002 | 08:02 AM
dustin's Avatar
Let me see if I can clarify...
Lets take two cars. Integra LS. Same Weight. Same final drive. Same gearing. Same amount of available traction. Understand that this is entirely hypothetical.
Assume that a shift at 7000 drops the car to 5000rpm in every gear.
Car 1
RPM torque horsepower
5000 300 285
5500 250 260
6000 200 228
6500 150 185
7000 100 133
Avg 200 218
Car 2
5000 100 95
5500 150 157
6000 200 228
6500 250 309
7000 300 400
Avg 200 238
Looks like car #2 has 20 average horsepower more through the RPM band, correct?
Which car will accelerate faster? At the end of EVERY gear, these imaginary cars will be exactly equal -- perfectly synchronized. They will have accelerated exactly as their torque curves show. At 5000 rpm, car 1 will be ahead, but by 7000 rpm car 2 will have caught up. This is because average torque is equal.
Dustin
Old Oct 1, 2002 | 09:26 AM
DIRep972's Avatar
Smarter than you
Car 1
5000 300 285
5500 250 260
6000 200 228
6500 150 185
7000 100 133
Avg 200 218
Car 2
5000 100 95
5500 150 157
6000 200 228
6500 250 309
7000 300 400
Avg 200 238
Dustin
I dont believe so dustin. We are all thinking along the same lines, which is, that torque in the right place is what makes a car accelerate, but I think you are overlooking the fact that hp is just a representation of how many times you can apply torque over a given time period. In your hypothetical situation, I honestly think the car with more hp would win. why? because the two motors are applying the same amount of torque to the crank/drivetrain/wheels. but in the given time of the race, motor 2 will have applied the same amount of torque on the crank more times then motor 1. causing the drivetrain to rotate and rotating the wheels more times then car one, thus it will be at a higher mph.
Old Oct 1, 2002 | 10:01 AM
chri5's Avatar
I fully agree with this. You would want to have the car whicc produced the most torque at the highest rpms. The higher the rpm the torque is produced at, the more often it is produced. HP is more of a rate at which power is produced, as opposed to the actual power produced, which is the torque.
Damn I havent posted here in a while.
