Post all ur t-70 turbo setups here.
89 civic std hatch with b16 going ls/vtec turbo
b18a
wiesco 8.5 to 1 comp
eagle rods
type r oil pump
acl race bearings
gsr girde
b16 head
s2s2 cams and valvetrain
dh-racing.com race port and polish head
Turbo parts
t-70 turbo
custom twisted manifold (Now going with a bryson top mount)
38mm wastegate 10psi and 15psi springs (Now 44mm wastegate)
Greedy type rs bov
m factory sandwich plate
godspeed type-L black intercooler
custom 3" mandrel bent downpipe
custom 2.5" mandrel bent intercooler piping
780cc injectors (Now 880cc or 1000cc injectors)
Tuning
Will Be tuned with BRE by j-k-tuning since im staying obd0.
should be complete and running by christmas.
Im Shooting for 375-450whp on pump gas.
(Now 525-600whp on race gas)
Please post ur t-70 setups also thanks.
Modified by Civic89stdB16 at 9:22 PM 11/1/2007
b18a
eagle rods
type r oil pump
acl race bearings
gsr girde
b16 head
Turbo parts
t-70 turbo
Greedy type rs bov
Tuning
Re: Post all ur t-70 turbo setups here. (Civic89stdB16)
t70 for 400 whp?? Thats alot of turbo. You b16 will have a hard time spooling that thing. Why don't you go with something a little more convential? A t3/t4 57 trim will get you there with fast spool time. If you wanted to go bigger with the intention of future upgrade, you could still get an sc60 or something, but a t70 is overkill.
Mr. Badwrench
Re: Post all ur t-70 turbo setups here. (hotimportcrx)
that it a lot of turbo for that power level, my 67ho at 520 was kinda laggy but it was nasty.
either way g/l with the build
Man U FTW
Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">a T70 is crazy for that power level</TD></TR></TABLE>
i agree...its too much turbo for your goals. Get a SC61 and you'll have a lot less lag
its a 61mm turbo. its not a "real" t70 its a 61mm .70 a/r compressor with an .84 exhaust. exhaust housing is a twin scroll t3 flange with a vband. its the same compressor wheel as the gt35r, sc61, t61 etc etc. the specs on the ebay t70 are almost identical to a gt35 only journal bearing....they are commonly called the poormans gt35.
Re: (fast2camciv)
I have actually decided to sleeve my block so i can crank the boost up 2 around 20psi and am now going to get a top mount from bryson, 880cc or 1000cc injectors, gm 3 bar, and my new goals are for around 525-600whp on 104 race gas. Is going to be a drag car only exept for an acational drive around town since its tagged till next december.
May go OBD1 and go with chrome or neptune.
Modified by Civic89stdB16 at 9:23 PM 11/1/2007
Man U FTW
Re: (Civic89stdB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 »</TD></TR><TR><TD CLASS="quote">May go OBD1 and go with chrome or neptune.</TD></TR></TABLE>
...and what had you planned to do before that?? You really should look into Hondata or AEM
were talking ebay t70 here. i think that could be gathered from this thread. a real t70 is huge. my t70 is a 61mm turbo, i took it apart and measure everything the minute i recieved it. again its the same size as a gt35, sc61, t61
Heres the crx with the T-76 Q trim
[IMG] [/http://a414.ac-images.myspacecdn.com/images01/96/l_510194b200985b43e94c18a0fcbe2ae5.jpgIMG]
Re: (fast2camciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast2camciv »</TD></TR><TR><TD CLASS="quote">its a 61mm turbo. its not a "real" t70 its a 61mm .70 a/r compressor with an .84 exhaust. exhaust housing is a twin scroll t3 flange with a vband. its the same compressor wheel as the gt35r, sc61, t61 etc etc. the specs on the ebay t70 are almost identical to a gt35 only journal bearing....they are commonly called the poormans gt35.</TD></TR></TABLE>
its an ebay t70...= 61mm
Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt »</TD></TR><TR><TD CLASS="quote">
its an ebay t70...= 61mm</TD></TR></TABLE>
correct
correct
Mr. Badwrench
Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">not to mention a t70 on a 38mm wastegate whats the turbine specs?</TD></TR></TABLE>
it can be done ben, jeff tamed my 67ho on dans dar at 10 psi with a 38mm gate. no spike or creep. i wouldnt do it though.
im positive that its called a "super t70" cause of the .70 a/r compressor...kinda taking after the "super 60" here is my setup.
GSR motor, cams, pistons, rods, t70, xspower manifold blah blah blah....im on 15psi right now, with a severe bog at the track i trapped 121, im sure it could go 125-127 easy. i figure im around 375-400hp...anyways.
