Possible oil feed from B16a head?
Old Oct 3, 2002 | 07:11 PM
rioninja's Avatar
Default Possible oil feed from B16a head?
I've been thinking about trying to use this plug as an oil feed line. (Pic stolen from Endyn site)
The only thing i'm worried about is if it would cause too much of a pressure drop, and interfere with vtec operation. It seems like a good idea; less line to run, and no more t-ing into the oil pressure sensor.
Old Oct 3, 2002 | 07:13 PM
tony1's Avatar
Default Re: Possible oil feed from B16a head? (RioNinja)
That plug only has about 7psi until vtec kicks on. DON'T use it for an oil feed. If it was that easy i'm sure everyone would do it!
Old Oct 3, 2002 | 07:22 PM
rioninja's Avatar
Default Re: Possible oil feed from B16a head? (tony1)
Yeah, i forgot about the fact that it would have no pressure until the solenoid opened. I thought it was too conveniant. Thats why i posted
Thanks
Now the vtec oil pressure sensor location, now that would work...
[Modified by RioNinja, 11:23 PM 10/3/2002]
Old Oct 3, 2002 | 07:54 PM
DUCK COMMANDER's Avatar
don't mean to be ignorant..but why not use the back of the block
Old Oct 4, 2002 | 03:13 AM
DSF's Avatar
DSF
Yep, there was a big debate about this last year. Can't find the post now If for some reason you against the stock oil pressure switch location, you can use the plug underneath the distributor. It receives the same system pressure.
Old Oct 4, 2002 | 06:54 AM
rioninja's Avatar
Default Re: Possible oil feed from B16a head? (JSutterEH2)
I have no problem with the oil pressure location, but it would be nice to have a short direct line instead.
Old Oct 27, 2002 | 02:01 AM
safe driver's Avatar
Default Re: Possible oil feed from B16a head? (DSF)
here ya go.
https://honda-tech.com/zerothread?id=93550
ivan93egreppin210
Jun 6, 2008 09:04 AM
MidwestAutoWorks
May 21, 2007 11:44 AM
electric_rex
Sep 19, 2004 09:40 PM
lemongreenhatch
Jun 26, 2004 07:24 AM
b20b
Feb 22, 2002 03:42 AM
