possible to drive w/o boost?
Old Jun 14, 2002 | 03:43 PM
ceemarun's Avatar
Default possible to drive w/o boost?
heres my problem. im installing my own turbo, and then i'll have to drive about 90 miles to the tuner to get the power fc tuned. i have an fmax kit, minus the mf2, so i have a turbo kit w/o any sort of fuel management. i hadnt driven a turbo car before. i'll be putting in the injectors at the place. any suggestions as to what i should do? i dont want to tow it there. costs too much.
Old Jun 14, 2002 | 04:02 PM
Jared's Avatar
Default Re: possible to drive w/o boost? (ceemarun)
Just keep it out of boost. Won't be difficult, just use light throttle all the way.
Old Jun 14, 2002 | 04:15 PM
B20LS-T's Avatar
New User
Default Re: possible to drive w/o boost? (Jared)
Im gonna be in the same situation but in a different way, hehe
Old Jun 14, 2002 | 04:22 PM
FBP Si 2000's Avatar
Default Re: possible to drive w/o boost? (B20LS-T)
Ah, so you're using the Power FC. Let me know how that turns out for ya, heard some good things about them.
Old Jun 14, 2002 | 06:33 PM
ceemarun's Avatar
Default Re: possible to drive w/o boost? (FBP Si 2000)
ah, i MIGHT use the power fc. i just got a really good deal on one. but i found out full tuning will be in the ~$2k area, so i doubt i am.
Old Jun 14, 2002 | 06:42 PM
Wow, ~$2k for tuning...
Old Jun 14, 2002 | 09:59 PM
shadowdawn's Avatar
If you REALLY wanna keep out of boost..... take your BOV completly off... I did this to test and see if it was working properly (unrelated) but you CAN'T generate boost with a hole that big in your charger pipe..... trust me I tried.
FYI also put some foam filter or wire mesh or something so stuff doesn't get sucked in.
Old Jun 14, 2002 | 10:04 PM
Mr. Softee's Avatar
Default Re: possible to drive w/o boost? (shadowdawn)
can't you take out the wastegate spring?
another option i've herad is not connecting the intercooler return pipe to the throttle body, and just putting a standard intake there.
Old Jun 14, 2002 | 10:25 PM
BlueSi2k's Avatar
wouldn't it be possible to over rev the turbo with the hole in the charge pipe? For this reason i also would not disconnect the charge pipe from the TB. Your best bet is taking out the wastegate spring and trying to keep off the throttle as much as possible. Hope this helps.
[Modified by BlueSi2k, 7:26 AM 6/15/2002]
Old Jun 14, 2002 | 11:02 PM
CovertFI's Avatar
Default Re: possible to drive w/o boost? (BlueSi2k)
this guy is right, yall are wrong (not being mean). your turbo has operating limits. and could easely over rev. that is just like disconnecting your rev limiter and just flooring it. letting it spin with out any restrictionl is very bad. probly the best thing to do is just connect your vaccume to the vaccume of the wg. it will suck it open unless you floor it then it will close and start to spool up. this way you will not have to open the wg at all.
Old Jun 15, 2002 | 12:27 AM
ceemarun's Avatar
Default Re: possible to drive w/o boost? (CovertFI)
thanks for all the info guys. so in simple terms, why cant i take off the bov again? it seemed like a really good idea.
Old Jun 15, 2002 | 03:07 AM
degradated's Avatar
New User
You don't need to go through all that. Just don't press down on the throttle more than 1/4-1/2 way. There have been days I've driven where I don't generate a pound of boost (rare ). When you want to, you can drive without spooling the turbo, it just requires self control.
Old Jun 15, 2002 | 06:00 AM
93LSivic's Avatar
Hmm, not hard. Have a boost gauge? IF so THEN LOOK AT IT! How hard is it, I mean, really????
Old Jun 15, 2002 | 07:02 AM
4-1-1's Avatar
Default Re: possible to drive w/o boost? (93LSivic)
Don't raise your RPM above 3500rpm?
Old Jun 15, 2002 | 07:13 AM
CovertFI's Avatar
Default Re: possible to drive w/o boost? (4-1-1)
i can bring my rpm to 6k and not boost, just dont go past 1/2 throttle or you will boost
Old Jun 15, 2002 | 07:44 AM
cracker099's Avatar
"Student Driver" sticker=
Old Jun 15, 2002 | 05:54 PM
SIK IN DA HED's Avatar
New User
so youre keepin the kit after all?
Old Jun 15, 2002 | 11:48 PM
Turbo Laser's Avatar
Default Re: possible to drive w/o boost? (dlplayboy)
I drove a N/A car once so it is possible...just not recommended.
mykulangot92
Mar 29, 2010 03:38 AM
1sicef9
Dec 1, 2009 07:21 AM
R3JEKT
Feb 1, 2008 10:39 AM
vagsreg6
Dec 21, 2005 01:30 PM
integra7
Nov 26, 2001 04:45 PM
