Is it possible to detonate in vaccum?
Old Jul 29, 2003 | 06:02 PM
superduperman's Avatar
Default Is it possible to detonate in vaccum?
When I accelerate under 3k and still in vaccum i hear this clinging sound. Im not sure if it's my intercooler pipes banging against my frame or denation. So is it possible to denoate w/o boosting?
Old Jul 29, 2003 | 06:10 PM
2000vsm's Avatar
Default Re: Is it possible to detonate in vaccum? (superduperman)
yeah, how you think normal cars without turbo detonate?
Old Jul 30, 2003 | 02:09 AM
Pengo's Avatar
detonation isn't something unique to only boosted cars
Old Jul 30, 2003 | 07:33 PM
Default Re: Is it possible to detonate in vaccum? (Pengo)
Well I dont understand how Im detonating in vaccum? My setup is a 12:1 FMU/Missing Link/MSD Inline fuel pump which should definetly suffice 5.5 PSI. Anyone got any ideas as to what could be wrong?
Old Jul 30, 2003 | 09:16 PM
XDEep's Avatar
well what is detonating? mixture igniting before its supposed to. so there can be many reasons like heat, running lean, timing, tuning..
Old Jul 30, 2003 | 10:07 PM
Default Re: Is it possible to detonate in vaccum? (XDEep)
Do you think running colder plugs would help? Im using stockies right now.
Old Jul 30, 2003 | 10:32 PM
Mase's Avatar
what engine management are you running?
Old Jul 30, 2003 | 10:53 PM
Default Re: Is it possible to detonate in vaccum? (Mase)
12:1 FMU, Inline Fuel Pump and please dont reccomend the hack or standalone
Old Jul 30, 2003 | 11:07 PM
JT's Avatar
JT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superduperman &raquo;</TD></TR><TR><TD CLASS="quote">Well I dont understand how Im detonating in vaccum? My setup is a 12:1 FMU/Missing Link/MSD Inline fuel pump which should definetly suffice 5.5 PSI. Anyone got any ideas as to what could be wrong?</TD></TR></TABLE>
Do you still have the stock FPR? If not, you should. Otherwise, the fuel pressure transition in vacuum will be kind of flat. The 12:1 FMU might not be able to handle smooth fuel pressure transition in vacuum. That's what the stock FPR is for.
Old Jul 30, 2003 | 11:15 PM
Pengo's Avatar
whats ur ignition timing set at?
Old Jul 30, 2003 | 11:16 PM
Mase's Avatar
if your ignition timing is near 16 degrees btdc, i highly doubt you are detonating under vac.
Old Jul 31, 2003 | 09:34 AM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superduperman &raquo;</TD></TR><TR><TD CLASS="quote">Do you think running colder plugs would help? Im using stockies right now.</TD></TR></TABLE>
a possibility. a colder plug is meant to extract more heat from the chamber. have you been checking the plugs?
Old Jul 31, 2003 | 09:47 AM
Teg4e's Avatar
probably not detonation that low in the power band, and in vaccuum. Technically, N/A cars are probably at 0 vac/boost if they're deonating...i.e. WOT.
Old Jul 31, 2003 | 05:57 PM
Default Re: Is it possible to detonate in vaccum? (Teg4e)
As I pay more attentino to the sound it sounds more like metal banging against metel.....kind of a quick rattling type of sound. Im starting to think it might be my intercooler pipes banging against the frame or something. Anyone else got any ideas?
Old Jul 31, 2003 | 05:59 PM
boosted92's Avatar
Try wrapping some old rags around any IC pipes near the frame and go driving and see if it goes away. If you have access to some race gas flush the tank and dump in a bit and drive down the block and see if it still does it.
Old Jul 31, 2003 | 07:23 PM
civperc's Avatar
Default Re: Is it possible to detonate in vaccum? (boosted92)
have you taken a look/listen in the engine bay and front end area while the car's idleing?
Old Aug 7, 2003 | 10:25 PM
Default Re: Is it possible to detonate in vaccum? (untensadude)
Yah I have and nothing seems out of the oridinary. It detonation loud?
deca
May 3, 2005 12:15 PM
f1 vtec
Aug 28, 2004 07:50 PM
d15b7racer
Sep 4, 2003 06:31 PM
boostincoupe
Apr 10, 2003 12:48 PM
highmilehatch
Sep 2, 2002 06:33 PM
