Ported Compressor shroud?
Old Mar 5, 2006 | 10:10 AM
N20civicB18's Avatar
Default Ported Compressor shroud?
Just wondering what all the hype is about having a ported compressor shroud? also if its worth it for whatever reason how do I do it and what do I tell my machine shop?
Kyle
Old Mar 5, 2006 | 10:18 AM
b16hybridsol's Avatar
Default Re: Ported Compressor shroud? (N20civicB18)
i dunno why you'd call it hype. It allows you to safely run the bigger turbos that you are normally over the surge line on (compressor map)
Old Mar 5, 2006 | 10:48 AM
Blind-Fashion's Avatar
I hope some nice info is posted here. Subscribed.
Old Mar 5, 2006 | 10:56 AM
BLKTeg94's Avatar
Off of Garrett'ss website.
A Ported Shroud compressor (see Fig. 2) is a feature that is incorporated into the compressor housing. It functions to move the surge line further to the left (see Fig. 3) by allowing some airflow to exit the wheel through the port to keep surge from occurring. This provides additional useable range and allows a larger compressor to be used for higher flow requirements without risking running the compressor into a dangerous surge condition. The presence of the ported shroud usually has a minor negative impact on compressor efficiency.
jasrams
Honda Civic (2001 - 2005)
Apr 23, 2012 08:59 AM
89efDUSTY
Nov 21, 2008 11:42 AM
OrangeBoost
Jan 22, 2006 01:36 AM
