Compressor housing A/R selection. Help me out please.
Ok so Im looking to pick up a Super 60 for my D16. Ill be running 15-20psi and I use this car for everything from street, strip, auto-x.
Ive decided to go with the .48A/R turbine housing but I have the choice between a .42A/R and .60A/R compressor housing.
Which should I go with and what effect will this have?
Re: Compressor housing A/R selection. Help me out please. (OrangeBoost)
the bigger the compressor a/r the more efficent the compressor is.. get the biggest one you can
Man U FTW
yes they do change...the efficiency island should move up into a higher area...it will be a little less efficient at lower power, but better at higher....i hope i said that right
Re: (Schister66)
Ok that makes sense but nowhere on the compressor map do I see it specifying the compressor A/R? So how do I know?
Would a super 60 map generall be for the larger or smaller housing?
Re: (OrangeBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett Turbos »</TD></TR><TR><TD CLASS="quote">Compressor performance is comparatively insensitive to changes in A/R. Larger A/R housings are sometimes used to optimize performance of low boost applications, and smaller A/R are used for high boost applications. However, as this influence of A/R on compressor performance is minor, there are not A/R options available for compressor housings.</TD></TR></TABLE>
Re: (k24em2)
Ok so it says smaller A/R for high boost. Would 17-20psi be considered high boost?
In which case I should go with the smaller housing? Intuitively this doesnt make sense to me.
Can someone please explain further?
Re: (OrangeBoost)
I'm wondering the same thing. I have a Super 60 with the .42 a/r comp housing and was wondering if upgrading to the .60 a/r housing was worth it.
Re: (k24em2)
No.
No.
Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 »</TD></TR><TR><TD CLASS="quote">
No.</TD></TR></TABLE>
Care to go into a little more detail?
Re: (OrangeBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett Turbochargers »</TD></TR><TR><TD CLASS="quote">Compressor performance is comparatively insensitive to changes in A/R. Larger A/R housings are sometimes used to optimize performance of low boost applications, and smaller A/R are used for high boost applications. However, as this influence of A/R on compressor performance is minor, there are not A/R options available for compressor housings.</TD></TR></TABLE>
For the third time.
For the third time.
Re: (k24em2)
For the third time.</TD></TR></TABLE>
Cliff notes: Changes in compressor A/R alone will have little to no effect on turbo performance.
Re: (k24em2)
My bad. I didnt realise you were replying to that post asking if it was worth it.
I thought you were disagreeing with that info.
Re: (elpiar)
A/R has nothing to do with how big the housing is physically. It's just a ratio of the radius of the scroll and how far away from the center it is.
MrBond
08-15-2004 01:15 PM
