pls help settle a long dispute
Old Aug 13, 2002 | 09:57 AM
EF_LSVtec's Avatar
Default pls help settle a long dispute
this person claims that a B16a turbo with less boost will run the same time as a B18a/b with higher boost. If a B18a/b can handle as much as 13psi of boost with stock internals...how much boost should B16a do to match...? And to add another Q...will a B16a motor perform better on turbo than a B18a/b...
Old Aug 13, 2002 | 10:07 AM
DSF's Avatar
DSF
Default Re: pls help settle a long dispute (EF_LSVtec)
Answer: letter "E"...not enough information to make an informed decision.
Too many variables left unaccounted for.
Old Aug 13, 2002 | 10:14 AM
CovertFI's Avatar
Default Re: pls help settle a long dispute (DSF)
such as are the motors built or not, fuel management?, weight of cars? so many diffrent things to consider.
Old Aug 13, 2002 | 10:15 AM
EF_LSVtec's Avatar
Well...stock B16a vs stock B18a/b...he claims that since a B16a is a better motor than a B18a/b, it should perform better too with a turbo. I disagree because of the B16's higher compression will not perform any better than a B18a/b.
Old Aug 13, 2002 | 10:22 AM
DSF's Avatar
DSF
...what manifold design, turbo specs, exhaust size, yada, yada, yada. An <U>improperly set-up</U> fully built, sleeved, alcohol injected, Motec controlled, T78 powered, 2.6L beast could be beaten by a DRAG3 equipped D16. Anything is possible.
Old Aug 13, 2002 | 10:24 AM
EF_LSVtec's Avatar
I guess I needed to spell things out, but we were discussing/debating over the same set up except for different motors...
Old Aug 13, 2002 | 11:23 AM
Smashback's Avatar
Same setup different motors same boost of course the B16 will put out more power. The high compression makes more power, but limits the amount of boost you can run. It's hard to say without dynoing them side by side though. You can't just say ok, 8 lbs on the B16 and 8lbs on the B18, then add 4lbs to the B18 and it's better because you don't know how much HP you are getting per lb of boost.
Old Aug 13, 2002 | 11:59 AM
EF_LSVtec's Avatar
Default Re: pls help settle a long dispute (mplex2000)
Good enough mplex2000...thanks
Old Aug 13, 2002 | 12:11 PM
dustin's Avatar
the b18b is going to make more torque than the b16 though -- always
Old Aug 13, 2002 | 12:51 PM
shadowdawn's Avatar
Default Re: pls help settle a long dispute (dustin)
::loves his b18b :D :: ::loves his torque::
johng89EKcoupe
Jan 24, 2012 04:16 PM
archmage
Jun 1, 2005 05:24 AM
dand39
Sep 13, 2003 09:57 AM
WuShu
Jul 23, 2001 11:23 AM
