please look at my turbo and tell me how much hp i should get from it
just as the topic says. its a t3/t4 turbonetics turbo, ceramic ball bearing section, stage v exhaust housing with a .63 and a 60-1hifi compressor . it was balanced to .2 g's at 62,000 rpms? here r some pics. if they dont work can somebody tell me how u post images from imagestation? here is the link to the album
http://www.imagestation.com/album/?id=4287837629
Re: please look at my turbo and tell me how much hp i should get from it (Prelude91siT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT »</TD></TR><TR><TD CLASS="quote">just as the topic says. its a t3/t4 turbonetics turbo, ceramic ball bearing section, stage v exhaust housing with a .63 and a 60-1hifi compressor . it was balanced to .2 g's at 62,000 rpms? here r some pics. if they dont work can somebody tell me how u post images from imagestation? here is the link to the album
take orig.jpg off
take orig.jpg off
Re: (Prelude91siT)
I just looked at it and it said to me 500hp! (sarcasim).....ok got that out of the way, What kind of setup are u runnin this on?? Whats your power level goals? How many girls you plan on picking up a night with that bad boy? With the additional info someone can better give you a probable guesstimate of what you can look forward to...cause in all seriousness different motors will see different results with that turbo.
Re: (TravSi)
i will be runnin it on a fully built block by gem and a gude head. my turbo kit looks like this
84mm bore
Golden Eagle Mfg. "Goldzilla" sleeves ( holds 60 psi of boost
Eagle rods
ACL engine bearings
Arias Pistons
Bored and honed
Line bored
Sized rods
Balanced crank and rotating assembly
Polished and chamfered oil hole crank
Blueprinted and assembled bottom end
84mm bore
Eagle rods
ACL engine bearings
Arias Pistons
Bored and honed
Line bored
Sized rods
oh no. i have a aem ems, aem wideband, gm 3bar boost seliniod, gm ait sensor and i'm getting 7 something cc injectors. the only thing i'm using from the kit is the a/w,downpipe w/ extrenal wastegate setup and manifold. this was the only bolt on kit ever produced for a 3rd gen prelude. so for now i have to take what i can get
Re: (Prelude91siT)
Is that an intercooler I see in that kit?
Get a frount mount for gods sake.
I'm impressed by your setup though. Nice motor, EMS... you should be able to make impressive numbers.
I hate these threads.
If I posted new tires should I ask how many miles I should get out of them?
Is that a t3/t4b? I see 7 blades on the compressor wheel.
