PLEASE HELP!!! mid range rev limiter while boosting ?
Old May 15, 2003 | 01:43 PM
spoon063's Avatar
Default PLEASE HELP!!! mid range rev limiter while boosting ?
my car was running fine on 5 lbs, then out of nowhere it wont boost past around 5000 rpms, i was running aem fpr, intank fp, fmu, stock injectors, brand new plugs, ive tried changing eveything to make a difference... @ about 1/4 throttle it will boost all the way through fine, but then when i try to get on the gas even a little bit it sputters and cuts off... ive tried adjustingthe fpr, bov, and vafc for tuning the fuel... ive heard alot that its running rich but ive leaned the hell out of it and its still the same... and i really dont know what else to try... and info or advice i would greatly appreciate... since this is my daily driver
Old May 15, 2003 | 02:29 PM
PM-Performance's Avatar
Default Re: PLEASE HELP!!! mid range rev limiter while boosting ? (spoon063)
try the plug gap , tighten it , i had the same prob
Old May 15, 2003 | 03:33 PM
spoon063's Avatar
Default Re: PLEASE HELP!!! mid range rev limiter while boosting ? (itr206)
i already gapped the plugs to .030
Old May 15, 2003 | 03:53 PM
Buckshot's Avatar
so pretty much it wont boost at wot....right mike
Old May 15, 2003 | 04:48 PM
its WANG yoO's Avatar
Default Re: PLEASE HELP!!! mid range rev limiter while boosting ? (Buckshot)
someone help Mikey!!!
Old May 15, 2003 | 06:46 PM
DragEG6 FI's Avatar
Default Re: PLEASE HELP!!! mid range rev limiter while boosting ? (VTEC93hatch)
What motor are we talking about?
Old May 16, 2003 | 03:53 AM
Default Re: PLEASE HELP!!! mid range rev limiter while boosting ? (Bsmoak)
99' b16a2,drag 3 kit,stock injectors,in tank pump,fmu,V-afc,P72 ecu.
i got u mike
Old May 16, 2003 | 05:26 AM
RGAZ's Avatar
New User
Check for a failed temp sensor. If the ECu thinks the engine is cold it will rev limit at a lower value, usually near 5000 rpm. The sensor could be faulty.
Randy
Old May 16, 2003 | 08:46 AM
spoon063's Avatar
Default Re: PLEASE HELP!!! mid range rev limiter while boosting ? (RGAZ)
if your talking about the sensor that controls the fan out of the thermostat i have that plug jumped to run the fan on full time. It wouldnt turn the fan on when it heated up
Rev Hard9999
Jul 13, 2007 10:14 PM
Ricey McRicerton
Oct 1, 2003 08:05 PM
sneakypete
May 29, 2003 02:35 PM
B17aTrbo
Oct 23, 2001 03:55 PM
