Please Check my oil feed line (pics)
Edit:
New Pics!
Hey guys,
I'm concerned with the slope of the feed line, specifically where it curves by the A/C condensor to the turbo - I think it might be "too sharp".
Ideas/Suggestions .. Thanks
Modified by FredoSP at 10:57 AM 3/27/2004
New Pics!
Hey guys,
Re: Please Check my oil feed line (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">I don't think it's a problem. correct me if I'm wrong But I believe I'm sure. It's pressure so it's cool</TD></TR></TABLE>
Yes, the feed line does have pressure, if it is hooked up to the oil "pressure" sender, which I believe is what he used for his oil feed source. Personally I routed mine under the engine, but that should work fine.
Jake D.
Jake D.
Re: Please Check my oil feed line (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 »</TD></TR><TR><TD CLASS="quote">thats a clean *** motor yO
-Brian</TD></TR></TABLE>
And you see it in person just about every day!
Re: Please Check my oil feed line (BlackKnight7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackKnight7 »</TD></TR><TR><TD CLASS="quote">
Jake D.</TD></TR></TABLE>
Yes its routed from there, but now I'm wondering if its smart to have the line on the valve cover ... hmmmm
Re: Please Check my oil feed line (FredoSP)
SS braided line is some nasty stuff if left untamed it can work like a saw. This is especially bad for powder coated aluminum valve covers. I have mine zip tied in a couple places so it won't saw threw stuff.
Jake D.
Jake D.
hummm, it will work fine because the line is pressurized, but it's kinda fugly having it over the motor like that, try running it around the other side.
HT's Biggest Loser
If you hit a bump or soemthing the valve cover and hood may sandwhich it and kink it. I would (and did) route it around the valve cover
Re: Please Check my oil feed line (SIXTYdashONE)
Fred,
I told you this already, I think. Route it from the tranny side...it's easier and you'll have a better angle to mount them.
stan
stan
Re: Please Check my oil feed line (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 »</TD></TR><TR><TD CLASS="quote">
Fred Lisen to Stan </TD></TR></TABLE>
he's to busy checking out other guys hahah LOL J/K man
The braided lines do very BAD things to whatever they come in contact with.
We routed rachels around over the trans, and put a piece of slit rubber hose over it to prevent rubbing damage.
like this:
like this:
Re: Please Check my oil feed line (ThePunk)
damn. looks like you bought every little nic nac brand new or something. kleen!
OT: how come ur block is so clean compared the pics of when ur block just got finished being assembled? is it painted?
EDIT: yea, you should route the oil line on the tranny side. if you leave it as is, it'll start scuffing up your valve cover and watever else its rubbing up against.
as long as the oil feen line is not kinked your ready to go dude !
this one look pretty damn good to me, no prob's here
KRanked
KRanked
Re: Please Check my oil feed line (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">Fred,
stan</TD></TR></TABLE>
Re: Please Check my oil feed line (lilxvtecxpwr)
Sure is painted
He painted everything possible on the motor and beleive me it looks damn good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilxvtecxpwr »</TD></TR><TR><TD CLASS="quote">damn. looks like you bought every little nic nac brand new or something. kleen!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 »</TD></TR><TR><TD CLASS="quote">Sure is painted
even the damm coolant over flow bracket and bolt!!!
I had mine runnin on the tranny side, no sharp bends, so it never gave me any problems. Also, it wasn't really coming in contact with anything, so nothing got chewed up.
