Please advise me
Old Mar 14, 2011 | 12:43 AM
Karl(FOB)'s Avatar
Default Please advise me
Hi everyone first of I’m a newb to Hondas. So here I go I just picked up a 2000 civic Ex stick ALL STOCK I MEAN ALL. I would like some advice from people that know what they’re doing with Hondas there’s nothing wrong with it so I can start upgrading it of the get go, this is what I’m thinking of doing to the car my goal is 300whp car for the street (LIL FUN tuner with a BOOST) I’m thinking of going with a B18b1 swap to start. Then B16a2 head (LS vtec). Step 3 type r trans or 00 SI trans (SAME THING ?). Step 4 sock setup on some boost no more then 9/10 psi ( want to be safe) full tune for sure then pistons rods and head work down the way and upping the boost to 15 psi with sporting mod air manifold , fuel, ect.. so my question is am on the right path or am I way of and wasting my time ? and I’m looking to put $300 in to the car every month so going with K –swap is a lil out of my range and I think D-series is a waste of time (no offense to any one ) H is weak (what I heard ). Any help is really a preheated and thanks for YOUR time.
Old Mar 14, 2011 | 01:53 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Please advise me
You can run those boost levels on stock internals with a good tune
Old Mar 14, 2011 | 02:00 AM
Karl(FOB)'s Avatar
from what i hear that 8 to 10 is all good 15 your ****ed but im not sure so if any one knows for sure LET US KNOW
Old Mar 14, 2011 | 09:03 AM
TheShodan's Avatar
Moderator
Depending upon the turbocharger used. 8-10 on turbocharger at 49lbs/min boost pressure (like in a T3/T04E 50 "trim") is different from 8-10 on a 75lbs/min turbo (like a T3/T67)
Old Mar 14, 2011 | 10:01 AM
98integralsB18's Avatar
I would stick with either a full ls motor or a full b16 motor. Do not swap a ls/vtec in it. Your on the right path but I would do as much as you can at once saves time later on instead of redoing the same steps.
Old Mar 14, 2011 | 10:33 AM
Karl(FOB)'s Avatar
thank you for that i was thinking of strting with T3/T4 on a stock moter.( learn how to drive under boost ) [QUOTE= I would stick with either a full ls motor or a full b16 motor. Do not swap a ls/vtec in it. Your on the right path but I would do as much as you can at once saves time later on instead of redoing the same steps.[/QUOTE]
well id love to do it all at once but wont have the $$$$ for it.and im not planing od driving the car in the snow i got a DD for that sow redoing things sound like fun l But y go with a B16 ? not a LS or even a GSR (LS cheap thats y i sed that )thanks for the help tho
Old Mar 14, 2011 | 10:49 AM
I have a built and turbo ls, but if your gonna end up build a block I would do b16 because the stroke is shorter so you can rev it more in my opinion. If you were not planning on revving the **** out of it a gsr or ls would be perfect. Ls is cheap and you can easily make 350 to 400 on stock sleeves. Everyone I talk to says anything over 400 even 350 with out traction solutions its stupid to drive on the street.
Old Mar 14, 2011 | 10:55 AM
Karl(FOB)'s Avatar
300 is my max i think its only a street car. whats the rev limit on bilt LS VS B16 ?
Old Mar 14, 2011 | 11:08 AM
Well stock vs. stock ls is like 7100 and a b16 is 8200. But if your goal is only 300whp you could just turbo a stock LS for cheaper on like 12-14 psi and be around 300 give or take.
Old Mar 14, 2011 | 11:30 AM
Karl(FOB)'s Avatar
what if i bild the ls can i rev more (i like the 1.8 set up ) and u have to have honda with vtec its just wrong not to lol
Old Mar 14, 2011 | 11:39 AM
haha yeah i could see that. But to make a ls rev more you need arp rod bolts or a rod and piston combo and springs and retainers and valves if you can. Weak link in an LS when it comes to revs is the rod bolts and springs.
Old Mar 14, 2011 | 11:48 AM
Karl(FOB)'s Avatar
i was looking at egale rods or crower and cp pistos 9.5to1 i think set up for boost and a bilding a head with skunk2 goodys sum pro2 cams (good or bad for boost not sure) what dos a full LS swap run ?
Old Mar 14, 2011 | 11:53 AM
SovXietday's Avatar
If 300hp is your goal you don't need to build the motor. These engines can withstand that kind of horsepower without issue.
Spend the money on a nice turbocharger setup and an even better tune. You'll be all set that way.
Old Mar 14, 2011 | 11:57 AM
Depends, it all varies on price some people think they have a gsr motor and try to get like a grand which is way out of range. I would pay like 300 or 400 for a motor with normal miles, 200 for an ls tranny, axles maybe like a 100, and for ecu a p72 like 50 bucks. but it really depends like i bought a 94 integra with a ls for 700 bucks drove it home. it really all depends if you keep your eye open you can find good deals.
Old Mar 14, 2011 | 12:07 PM
Karl(FOB)'s Avatar
so 600 wood be a ok bay and this is a drop in swap no welding i can use my mounts ( no $ fot hasports at first)i wood just get new axles. "a nice turbo set up" get a kit or sprit parts? thanks alot for all your help evrey one
Old Mar 14, 2011 | 12:17 PM
SovXietday's Avatar
It's best to piece together your kit yourself. Works two ways, one, you can get good parts where good parts matter and save some money on cheap parts where it doesn't (IC piping for instance). Also, you learn all of the parts that you need and how they all work so if you have a problem you have a better chance of solving it.
Old Mar 21, 2011 | 10:03 AM
Karl(FOB)'s Avatar
ok cool good to know thats what i will do then. and i did pick a moter this weak end from a junk yard for a 150 and it looks like the block is good to go but i need to see if the valves are ****ed up cuz the timing belt was broken it looks like 2 valves mite have hit going to test this weak if it dont leak im alll good going to thorw it in with the ls for the time beaing.
ej1_Łopez
Jun 1, 2013 07:45 AM
91_civicsi
Honda Civic (2006 - 2015)
Sep 4, 2008 07:10 PM
LsVtecFoti
Feb 16, 2008 10:54 AM
Techno Tonis
Jun 30, 2007 10:06 AM
DutchEG6
Aug 20, 2005 06:29 AM
