Platinum Plugs with N20
Old Oct 6, 2003 | 01:27 PM
-Trinitron-'s Avatar
Default Platinum Plugs with N20
Ok, so I have had assorted NGK plugs in my car and I fianlly went and got the correct ones for my 99 Si. The part number it called for in the manual was for a platinum plug. I have heard that you aren't supposed to spray on Platinum plugs. Something about the platinum melting while on the bottle. Is this true? Or should I not worry about it.
In my searches all I found were the BEST NGK plugs to spray on, not whether or not I could spray on mine.
Old Oct 6, 2003 | 03:40 PM
GSRswapandslow
Guest
Posts: n/a
just get some bkr7e's and be done with it
$1.09 apiece
Old Oct 6, 2003 | 03:44 PM
Jared's Avatar
Default Re: Platinum Plugs with N20 (-TRINiTRON-)
yup 7 heat range should do, the only advantage to platinum is that they last longer.
Old Oct 6, 2003 | 04:10 PM
GSRswapandslow
Guest
Posts: n/a
platinum is junk
plain and simple
**** some iridium **** too
Old Oct 6, 2003 | 04:16 PM
the1eddins's Avatar
Default Re: (GSRswapandslow)
DONT DO IT
platinum on fi or sprayed cars equal misfiring, detonation and overall shittyness, my buddy's gst gained 17 hp at the wheels just by changing to good ol copper plugs
Old Oct 6, 2003 | 04:38 PM
Yeah I was always under the impression that platinum was junk too, but I have also read all over the place that the stock NGK's are the best for your car. The stock plugs are platinum! So, any suggestions on which plug I should run normally? or should I run the 7's all the time? Should I close the gap for daily driving?
Old Oct 6, 2003 | 04:41 PM
Vadian's Avatar
Platinum is junk with n2o. I exploded all the electrodes when I was on nitrous. Simple change of the plugs and no more problem.
OMG
14
Jul 15, 2014 08:17 AM
TravisCadello
14
Feb 4, 2009 11:41 AM
dpdawson
Honda Civic (2001 - 2005)
24
Dec 22, 2008 08:29 PM
gsrguy
Jan 23, 2004 07:04 AM
maggsgsr
Apr 4, 2002 08:18 AM
