plans for a new F/I SOHC d-series.
About time for my STOCK del sol to be not so stock for this up and comming summer , my plans include go force inducted. i plan to add:
SOHC JRSC
new intake manifold gasket
K&N cone filter on stock intake arm
EX/Si tranny
new battery
spark plugs/wires
DC sports 4-1 header
custom piping with ES oval muffler
now my question is, should i get a new fuel pump and injectors too? the car is a D.D. and i want it to run better than now. thats the reason plug,battery,wires etc.
So, what other little things should i go ahead and get to get this car running good? not going for all power here
SOHC JRSC
EX/Si tranny
new battery
spark plugs/wires
Re: plans for a new F/I SOHC d-series. (Squallie)
Look into 450cc DSM injectors and a hondata/Neptune/Uberdata/crome and you will be 2341341234123412345456 times happier.
liam
Re: plans for a new F/I SOHC d-series. (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
im am not to big on knowledge of ecu's/electronics. can you or somebody explain what the hondata/Neptune/Uberdata/crome will actually do and retail?
EDIT: what about a fuel pump?
hondata/neptune/uberdata/crome/etc are all engine management systems that run off of your ecu. It lets you, or a tuner in most cases, manually change any of your maps so the car runs better while under this added pressure. Hondata is rouhly 300+ depending on what system you buy and is basically what the other three are based from. I'm not sure the price of neptune or even if it's offered for sohc. Uberdata and Crome are both free ... and arguably just as good as the others. I use hondata s300 in my setup ... there are a lot of sohc guys that use crome and uberdata though. Hope that helps.
Edit: I guess since 9/10 people will be running a p28 ecu or similar with neptune, it would almost have to be able to be used for sohc also... i've never looked into it and know nearly nothing about it but from what i've heard - it's awesome. Besides, it's backed by Jeff Evans, who's the **** ... and i believe full-race as well, who need no introduction.... and there are countless others using this product too
Re: (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage »</TD></TR><TR><TD CLASS="quote">get a better header </TD></TR></TABLE>
like what? im on a buget and its a D.D. so not looking for serious power. i looked at the SMP header but i want to keep my A/C
Re: (eg2phosizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2phosizzle »</TD></TR><TR><TD CLASS="quote">why are u getting headers when u plan to go turbo???</TD></TR></TABLE>
i never said im going turbo...?
Re: (miyagi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miyagi »</TD></TR><TR><TD CLASS="quote">Edit: I guess since 9/10 people will be running a p28 ecu or similar with neptune, it would almost have to be able to be used for sohc also...</TD></TR></TABLE>
I run a Neptune on a p28 on my d-series, runs awesome. There are lots of sohc guys out there with Neptune!
liam
liam
Re: (liam821)
the more i thought about it, the more i figured it had to be for sohc also ... thansk for clearing it up tho bro
EK FLY
10
03-25-2007 12:53 PM
Squallie
02-26-2006 02:45 PM
frostcivic
08-06-2004 02:22 PM
