planning to get FI 94 accord .
im new at FI never even looked into it, but my friend amazes me with his setup and was planning to do it to mine also.. wondering are there kits that can keep it simple, meaning everyday driving conditions, etc etc... most heads say keep it at 7psi and i should be good, but are there any other engine modifications i would need before going turbo... planning to order the drag 3 kit, any opinions on the kit? i have a good 5k to use on the kit... thanks in advance..
b.t.w - the cars a 94 lx coupe. p&p head and few bolt on goodies that came with the car when i bought it...
Re: planning to get FI 94 accord . (Mike813)
A basic drag kit with Hondata and some 550's 3" exh, fuel pump,boost controller, turbo timer. There go that should be around 5000 plus or minus a few dollars.
Re: planning to get FI 94 accord . (tSuperbike69)
wow 5g's sounds like a race ready turbo, i just need something around 7psi the most for daily driving... and i dont wanna do a h22a swap, wanna stick with the f22b2... they have kits on this site for $3199 http://imoto.com/shopsite_sc/store/html/index.html not sure if what the ycome with is good, any opinions?
Contact Ben at importparts.com on this site he will get you set up. If you want it to be reliable you need the Hondata do you want your motor resting on a fmu? The boost controller is the only item and turbo timer that I would even consider taking off the list.
