pistons
Old Mar 18, 2002 | 09:25 AM
Stunna BEN's Avatar
Don't call it a comeback
Default pistons
Best pistons from LSVtec Turbo? Searched for a few but i wanted more feedback...
Old Mar 18, 2002 | 09:28 AM
b18bturbo's Avatar
Default Re: pistons (LunEG)
how big bore ar eyou running on yuor motor factory ls bore 81mm or 81.5mm or have you sleeved it and went 84mm
Old Mar 18, 2002 | 09:38 AM
Stunna BEN's Avatar
Default Re: pistons (b18bturbo)
Stock bore. I do not plan on running over 8-10psi and i dont plan on going over 8000-8100rpm. I already have ARP rod bolts. What else would you do to the bottom end? I was hoping to shot peen the rods so they would be able to hold.
Old Mar 18, 2002 | 09:44 AM
b18bturbo's Avatar
i would get z10 girldle .there a good deal on some pistons in the classfieds section 8.5:1 stock bore size pistons 375 its chaep for soem JE pistons
Old Mar 18, 2002 | 10:04 AM
X2BOARD's Avatar
8.8 JE Piston, Eagle Rod
Old Mar 18, 2002 | 10:56 AM
ATurboCivic2NV's Avatar
Default Re: pistons (X2BOARD)
what is shot peen? i have heard of this but no one has ever explained
Old Mar 18, 2002 | 11:22 AM
X2BOARD's Avatar
Default Re: pistons (ATurboCivic2NV)
It's a method of taking heroin.... hahahahaha j /k...
Shot peening is a process that subjects whatever metal in question to some type of high velocity blasting that structurally strengthens the material to about 30-40% stronger...
I'm not an expert, as you can see by my explaination... but that's basically what it is....
nenetech
Jan 2, 2013 09:01 PM
spades614
Jan 30, 2012 03:04 PM
kidd_drastic
17
Dec 21, 2005 01:53 PM
s2kkid
Nov 24, 2004 04:38 AM
mz3bo
Jun 18, 2004 06:34 PM
