Piston to wall question
Old May 22, 2011 | 05:23 PM
  #26
Tjabo's Avatar
Default Re: Piston to wall question
Ring gaps are an independent thing from P2W clearance. I'm running what some people think are rather excessively wide ring gaps and my motor isn't using ANY oil...
And the consensus on P2W seems to be that the only problem you'll have from .0055" is a bit of cold slap possibly.
Old May 22, 2011 | 05:44 PM
  #27
vipersal's Avatar
But if you bore the sleeve to get more PTW clearance, you will be getting more ring gap, or not.
I have 0.0055 PTW, and my rings have 0.20, 0.22, 0.26 or closer, i dont remember.
Old May 22, 2011 | 06:28 PM
  #28
Tjabo's Avatar
Sure, but there's no reason to gap your rings until your P2W is established. In your case, didn't you start out with a large P2W number? If so, you won't be wanting or needing to open up the bore any more, will you? Did I miss something? Sorry if so.
Old May 23, 2011 | 11:33 AM
  #29
vipersal's Avatar
It was a mistake of the machine shop, my next step will be with a darton sleeves.
Old May 23, 2011 | 12:08 PM
  #30
WhiteEJCoupe's Avatar
i got a totally new block to redo it. just researchin a little more before i bore/hone this one. my 87mm .005 block is for sale for anybody who doesnt mind that spec..
for you guys saying .0045 is fine. are you on bseries or kseries? does it matter?
SiR Inspired ED7
Dec 18, 2007 04:07 PM
supergreenNA1
Mar 24, 2002 02:19 AM
maximedx
Feb 26, 2002 11:11 PM
