Is this piston slap?
Old Aug 8, 2012 | 09:26 AM
beat's Avatar
Default Is this piston slap?
Hi,
I recently had my motor rebuilt.
JDM B18C
CP pistons 81.5 11:1CR
Manley rods
Supertech valves, springs, retainers
Stock cams
JRSC/LHT
Ive been hearing these noises that seem to come from the bottom end, but whenever the car is warm, its completely gone. My friend said its piston slap. Would like to confirm it.
http://www.youtube.com/watch?v=Rj4r1...3&feature=plcp
http://www.youtube.com/watch?v=k2pO8...1&feature=plcp
http://www.youtube.com/watch?v=4Q9zA...2&feature=plcp
Old Aug 8, 2012 | 09:38 AM
kyden's Avatar
Default Re: Is this piston slap?
i have cp pistons with really loose clearances and it only slaps for about 3 seconds on startup (if that long even)
Old Aug 8, 2012 | 09:43 AM
TKERacer619's Avatar
Sounds like it.
What is the PTW clearances?
Shouldn't be a problem as long as you let it warm up.
Old Aug 8, 2012 | 09:53 AM
beat's Avatar
Originally Posted by TKERacer619
Sounds like it.
Hm... Im not sure what is the PTW clearance. I think there is a spec recommended with the pistons.
Old Aug 8, 2012 | 10:31 AM
JakeSpec's Avatar
.025-.035
Just checked the PTW on this sleeved block with Wiseco's
.025
Old Aug 8, 2012 | 10:39 AM
bigpunn421's Avatar
you run stock spec for stock pistons. aftermarket ones usually require different specs for p2w. plus if you boost it you want it looser
and jake spec i think you forgot a zero if your talking inches
Old Aug 8, 2012 | 10:52 AM
bigpunn421's Avatar
did you use a stethoscope to see if its coming from the head or lower end?
to me it does not sound too bad.
it could be the valves if they are upgraded or not adjusted correctly.
it also could be the new injectors. the aftermarket once are noisy
loose wrist pin?
but the sympthom of it being louder cold and getting quieter when it warms matches the piston slap perfect
Old Aug 8, 2012 | 10:56 AM
bigpunn421's Avatar
Originally Posted by JakeSpec
.025-.035
.025
he has cp pistons and he didnt mention a sleeved block.
cp reccomends about .0035" people run them alot looser for big hp
Old Aug 8, 2012 | 10:57 AM
JakeSpec's Avatar
i sure did and have been doing it for years smh
0.0025-0.0035 Correction
Thanks
Typically Piston slap is caused by the piston not being expanded untill it reaches a certain temp or Warms up a bit.
Ive heard some really loud blocks on start up and they quiet down after 20-30 seconds
GL
Old Aug 8, 2012 | 12:15 PM
sleepencivic's Avatar
sounds like piston slap to me
Old Aug 8, 2012 | 12:23 PM
Spawne32's Avatar
I see the problem.
Old Aug 8, 2012 | 07:04 PM
beat's Avatar
loose wrist pin?
I did not use a stethoscope, but it doesnt sound like its from the valve train, it sounds like its from the bottom end.
beat
25
Jul 27, 2016 12:54 AM
anjgsr
Mar 10, 2010 09:48 AM
xQB21x
Dec 18, 2009 02:49 AM
sky88
Aug 2, 2004 12:09 PM
smokinsi
Jul 25, 2004 05:51 AM
