Piston size....
Old Oct 28, 2005 | 03:57 PM
B18Sleeper's Avatar
Default Piston size....
ok i was lookin into pistons and i was wondering what the difference is when you go with a bigger piston? i seen cp pistons 81mm cr 9.0:1 and then 84mm cp pistons with the same cr. what is the advantage or disadvantage to a better piston? will it help or make any difference on a FI car? thanks
Old Oct 28, 2005 | 06:41 PM
B18 CYA's Avatar
81 or 84mm doesnt mean which ones better. the bigger the displacement, the more torque you'll make. so pretty much the bigger the pistons, the bigger the bore you have and the more torque you'll get
Old Oct 28, 2005 | 08:25 PM
B18Sleeper's Avatar
Default Re: (B18 CYA)
ok so i should get mine bored out as big as i can with a 9.0:1 cr? which will be 84mm? that will make higher torque numbers and not a higher hp number.
Old Oct 28, 2005 | 08:51 PM
B18Sleeper's Avatar
Default Re: (B18Sleeper)
am i off track or on the right one here?
Old Oct 29, 2005 | 07:00 AM
B18 CYA's Avatar
if u do that, you will have to sleeve your block. 84mm bore on stock sleeves will crack in no time
Old Oct 29, 2005 | 09:21 AM
B18Sleeper's Avatar
i was planning on sleeving it either way with daron mids
Old Oct 29, 2005 | 09:33 AM
B18 CYA's Avatar
then go with 84mm
Old Oct 29, 2005 | 09:36 AM
B18Sleeper's Avatar
is it stupid to sleeve, bore, and port/polish a motor when your build is for 400 to 450whp?
Old Oct 29, 2005 | 09:46 AM
B18 CYA's Avatar
for 400whp i wouldnt port/polish ... plenty of people making 400-450 without port/polish. and if you want to make 400+ whp id sleeve for safety...especially on 84mm bore
Old Oct 29, 2005 | 09:48 AM
B18Sleeper's Avatar
ok would u happen to know a good place to send my motor to get bored? i tried the search but it said the past 2 days that its temporarily unavailable or something.
Old Oct 29, 2005 | 09:51 AM
B18Sleeper's Avatar
oh and how much would i have to get it bored over to achieve 84mm? and i was lookin at the pistons i want CP and the place i was goin to get them from only carry 83mm 9.0:1 pistons so what would it take to achieve 83mm bore
Old Oct 29, 2005 | 10:27 AM
Riceintegrars's Avatar
hopefully i know wat im talking about
when ur overboring, ur thining out ur cylinder walls, so they become weaker, but since ur getting them sleaved, its no problem.
when u go to get ur block bored at the machine shop, they usually require u to bring ur pistons aswell, so they know it will fit.
Old Oct 29, 2005 | 10:32 AM
B18Sleeper's Avatar
Default Re: (Riceintegrars)
sorry my question was a little confusing..i want to know like when ppl say i bored mine .20 over...what will mine be bored over to get 83 or 84mm?
Old Oct 29, 2005 | 10:51 AM
SOHCD16y8's Avatar
every .020 overbore is .5mm
Old Oct 29, 2005 | 10:52 AM
B18Sleeper's Avatar
Default Re: (SOHCD16y8)
so it would be a .12 bore over? thanks man
Old Oct 29, 2005 | 10:57 AM
B18Sleeper's Avatar
anyone know a good place to send it too? or would it be just any machine shop can do it? what are the running price for boring something .12 over?
Old Oct 29, 2005 | 01:05 PM
NJIN BUILDR's Avatar
OK my head is spinning.Talk milimeters or inches.Standard bore is 81mm or 3.189".Plus .5mm is .020" (81.5mm or 3.209").To have the bore 84mm will require sleeving,thats too big for the stock sleeves.
Glenn
Old Oct 29, 2005 | 05:08 PM
B18Sleeper's Avatar
Default Re: (NJIN BUILDR)
yes and i am goin to sleeve it with darton mids.
Old Oct 29, 2005 | 08:57 PM
SOHCD16y8's Avatar
Not to be a dick but it seems like you are rushing into things and not planning it out very well. Think it through and do some research before buying this and boring that. In the matter of a day you went from not knowing anything about bore and sleeve to deciding to sleeve and bore to 84mm. Just some good advice to think about. The smallest mistake can screw your whole build.
Old Oct 29, 2005 | 09:10 PM
B18Sleeper's Avatar
yes and my build wont begin for another 5 months. which is why i am asking questions and tryin to learn now. just cause i say something now wont mean i will do it when i start my build.
Old Oct 29, 2005 | 09:12 PM
B18Sleeper's Avatar
thanks though..
Old Oct 30, 2005 | 10:40 AM
SOHCD16y8's Avatar
Just trying to help, dont want to see people making simple mistakes. But if it does come together as you are planning it will be a very strong car.
Old Oct 30, 2005 | 10:46 AM
B18Sleeper's Avatar
i hope so, i am planning this out completely. i mean i wanna go into it knowing what i want and what i need. i plan on parking my civic and pullin my motor in about 2 months but i am goin to do the body work first then start on the motor. it gives me more time to get all my motor in check. thanks for hte help tho
xjdmjunkiex
Feb 28, 2011 08:26 PM
user 98292739
Aug 15, 2009 07:26 PM
Yambor
Apr 29, 2005 10:55 PM
vtecb20coupe
Feb 4, 2004 01:47 PM
Benny Z
Dec 20, 2002 03:35 AM
