piston/rod combo
Old Jan 18, 2009 | 09:39 AM
99coupeEx's Avatar
Default piston/rod combo
been out the game for a while but i cant stay away too long. i have a y7 block y8 head mini me and i was wondering what rods would help bring up the compression of ome vitara pistons. id like for my compression to be someone around 9.1:1. any help picking out some rods since a turbo setup is only as good as its weakest component (rods on the y7 block) would be greatly appreciated.thanks.
Old Jan 18, 2009 | 09:55 AM
23hatchturbo's Avatar
Default Re: piston/rod combo
There is a company that makes a custom rod for vitara pistons pm me and i can get you some info.
Old Jan 18, 2009 | 10:14 AM
Schister66's Avatar
Man U FTW
Other than getting different rods, you could also deck the head and block. That should give you a little more static compression. If you find a compression calculator and type in all your measurements, you can see how much you'd need to deck those surfaces to get the compression you desire...
TravisBiggie
Feb 23, 2015 01:11 PM
CyberC1ren
Dec 18, 2013 07:33 AM
Leland
Oct 1, 2009 01:33 PM
lsturbo*
Sep 16, 2006 05:24 PM
ZedEx
10
Jun 12, 2005 02:37 PM
