piston ring seating
Old Nov 4, 2008 | 09:15 PM
2wheelhunter's Avatar
Default piston ring seating
i have done some research and for the most part i understand how to seat new piston rings. one thing i was told in the past was to pour about an oil cap of oil down into the combustion chamber before starting the engine. would this be neccessary? like i said i heard this but havent read it anywhere. help please!
Old Nov 4, 2008 | 09:25 PM
LA_HONDAS's Avatar
Default Re: piston ring seating (2wheelhunter)
if you put oil on the piston rings before installing them then there is no need to do that
Old Nov 4, 2008 | 09:27 PM
tony413's Avatar
if you are breaking the motor in i suggest doing it on a dyno its the best thing you can do in my opinion. now to answer your question, you're going to want to use 30 weight break-in oil poor a little down the compression chambers and then start the car up and drive it around for about 3 days with break-in oil ( if you're not breaking it in on a dyno). after that switch to non-detergent oil and drive the car for a while. then switch to your favorite detergent oil. or go buy this http://www.importbuilders.com/breakinarticle.htm or this http://laskeyracing.com/shop/breakin.htm
Old Nov 4, 2008 | 09:41 PM
one-cam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">i have done some research and for the most part i understand how to seat new piston rings. one thing i was told in the past was to pour about an oil cap of oil down into the combustion chamber before starting the engine. would this be neccessary? like i said i heard this but havent read it anywhere. help please!</TD></TR></TABLE>
im running into the same issue.. i can hear my piston rings scratching the walls whenever i turn the crank. its a fresh built engine not even started yet. would putting some oil into the chamber help?
Old Nov 4, 2008 | 09:47 PM
tony413's Avatar
read the links
Old Nov 4, 2008 | 10:11 PM
one-cam's Avatar
Default Re: (tony413)
my bad playa but it says nothing about pouring oil into the cylinders
Old Nov 5, 2008 | 06:13 AM
tony413's Avatar
Default Re: (one-cam)
yeah my addlibs.
Old Nov 5, 2008 | 07:05 AM
LastGenEK's Avatar
I installed mine with a cap full of Marvel Mystry oil 7,xxx miles strong ( not even a ful cap)
Old Nov 5, 2008 | 11:44 AM
Default Re: (LastGenEK)
i do plan on breaking it in on the dyno.. i have read all about NOT doing it on a dyno and it just doesnt appetize me..
thanks for the info!
Old Nov 5, 2008 | 12:03 PM
Default Re: (2wheelhunter)
i've also read in alot of places that on the initial start up that you are supposed to pull the spark plugs or unplug the dizzy.. now wouldnt that let fuel build up in the compression chamber? dont you NOT want that? doesnt the fuel clean the cylinder walls of oil? i have always pulled the ECU fuse out of the fusebox under the hood that way fuel doesnt sit in the chamber.
Old Nov 5, 2008 | 12:42 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">i've also read in alot of places that on the initial start up that you are supposed to pull the spark plugs or unplug the dizzy.. now wouldnt that let fuel build up in the compression chamber? dont you NOT want that? doesnt the fuel clean the cylinder walls of oil? i have always pulled the ECU fuse out of the fusebox under the hood that way fuel doesnt sit in the chamber.</TD></TR></TABLE>
You can pull the fuse or many programs you can just disable the injectors. Your basically just trying to get some oil pressure in the engine before you start it.
Old Nov 5, 2008 | 05:49 PM
Default Re: (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">
You can pull the fuse or many programs you can just disable the injectors. Your basically just trying to get some oil pressure in the engine before you start it.</TD></TR></TABLE>
so i assume my way is fine.. it has always worked in the past...
so cap of oil or no cap of oil that is the question
Old Nov 5, 2008 | 06:38 PM
LA_HONDAS's Avatar
its up to you
if you feel safe with a cap of oil on the pistons then do it
Old Nov 6, 2008 | 07:19 AM
Default Re: (LA_HONDAS)
thanks everyone!
Atomic1
May 12, 2015 11:56 AM
FireInTheHead
Nov 4, 2014 04:15 PM
blackeg
Apr 1, 2012 12:58 PM
joss731
Sep 15, 2010 08:50 AM
IloveNewt
Dec 21, 2003 10:18 AM
