piston ring in oil pan...
Old May 10, 2004 | 10:24 AM
z6's Avatar
z6
Default piston ring in oil pan...
heres the setup:
1.8 VTEC Block
84mm Darton Sleeves
JE 9:1 Pistons
Eagle H Beam Rods
Pro Drive Oil Pump Gear
Cometic Turbo Head Gasket
ARP Head Studs
Ported Head
Crower Valves
Crower Springs
Crower Retainers
Crower Turbo Cams
AEM Cam Gears
AEM Fuel Rail
AEM FPR
GReddy Timing Belt
Skunk2 Manifold Ported
ITR LSD
Centerforce Dual Friction Clutch
Just changed oil pan and found out there is parts of apiston ring in there...anyone know what can be fucked up in the engine?
Old May 10, 2004 | 10:32 AM
tgreaves's Avatar
Default Re: piston ring in oil pan... (z6)
Might have broke a ring land or just cracked a ring.. Doesnt seem likely with the parts that you have.. Either way I would check into it before starting or driving the car any more..
Old May 10, 2004 | 10:46 AM
z6's Avatar
z6
could it be a cracked sleeve? whats the worst that coulve happened?
Old May 10, 2004 | 11:01 AM
tgreaves's Avatar
Default Re: (z6)
Well if the motor was running before I would say the worst that could have happend is that you cracked a piston ring an maybe messed up the piston and scared the sleeve wall in which case youll need to put a new sleeve in that cylinder and get a new piston and rings.. Also rebuild the entire motor since you have to disassemble it for the machine shop to put the sleeve in if its that bad..
Old May 10, 2004 | 11:02 AM
boosted_dc2's Avatar
Default Re: (z6)
are you sure its a piston ring??? how big is it, have you done a compression check???
Landon
Old May 10, 2004 | 11:11 AM
tgreaves's Avatar
Default Re: (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">are you sure its a piston ring??? how big is it, have you done a compression check???
Landon</TD></TR></TABLE>
True.. I would do a compression and leakdown test before you pull anything apart.. Can you take a pic of what you found in the pan and post it on here..
Old May 10, 2004 | 12:28 PM
Br1t1shguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">heres the setup:
1.8 VTEC Block
84mm Darton Sleeves
JE 9:1 Pistons
Eagle H Beam Rods
ARP Head Studs
Ported Head
Crower Valves
Crower Springs
Crower Retainers
Crower Turbo Cams
AEM Cam Gears
AEM Fuel Rail
AEM FPR
GReddy Timing Belt
ITR LSD
Just changed oil pan and found out there is parts of apiston ring in there...anyone know what can be fucked up in the engine?</TD></TR></TABLE>
Well if it really is a ring, whats fucked up is that cylinder, and you'll need to resleeve and replace the piston. You might be able to get away with boring out if the scoring isnt too deep, but that means 4 new pistons.
Old May 10, 2004 | 12:49 PM
hackish's Avatar
Default Re: piston ring in oil pan... (Br1t1shguy)
Next question, it's part of which ring? What lead to this? How was it running before you pulled the pan off? It's quite difficult for a piece of ring to make it into the oil pan. especially since ring land failures tend to happen on the top at which point the pieces normally go out the exhaust.
HyperFlow
Nov 3, 2010 03:49 AM
slick1851
Jul 6, 2010 06:43 PM
slick1851
Jul 6, 2010 01:33 PM
slick1851
May 7, 2010 09:45 AM
95accordsir
Jan 19, 2008 04:01 PM
