piston matching question what CR comes out?!
Old 04-23-2003, 07:52 AM
austrian type-R's Avatar
Default piston matching question what CR comes out?!
http://www.jepistons.com/pdf/2...a.pdf
If I would put an B18C1 9.8:1 piston in an B18C5 engine I will get out an CR of 8.6:1, is that correct?!
But the quench area would get a bit more, right?
Old 04-23-2003, 07:58 AM
b18bturbo's Avatar
Default Re: piston matching question what CR comes out?! (austrian type-R)
check out c-speedracing.com and calculate your compression
Old 04-23-2003, 08:17 AM
Default Re: piston matching question what CR comes out?! (b18bturbo)
nice programm, but when I insert all the specs for B18C5 engine at http://www.jepistons.com I get out 8.46:1 cr and not 9:1 cr?!
Old 04-23-2003, 08:19 AM
b18bturbo's Avatar
werid it should be correct i know it works fine for the stock pistons..
Old 04-23-2003, 08:21 AM
yeah, I tried with stock pistons too, it is correct, but when changing to another Piston Dome Displacement (cc per piston) from the aftermarket piston homepages ...the numbes are way off from Wiseco or JE homepage.
Old 04-23-2003, 09:52 AM
boostaholic's Avatar
Everything else being equal, a piston that yields 9.8:1 in a b18c1 will net you about 9.6:1 in a b18c5 due do the larger combustion chamber volume. They both use the same bore and stroke so that's not different.
vinuneuro
07-30-2005 10:51 PM
siis2fast
06-07-2005 03:52 AM
gregsr
08-17-2003 01:49 PM
Jared
07-29-2003 02:06 PM
Quick Reply: piston matching question what CR comes out?!
