piston fried
Old Mar 20, 2002 | 09:00 PM
Tofurky's Avatar
Default piston fried
two weeks ago i took my car to famoso came back and the clutch was slipping(so i thought) and there was white smoke coming out from under the hood. so i figured it was just my stock clutch not liking my turbo. so today i take it to the shop to have them install a clutch, and i get a call from the guy, and he tells me that the smoke is coming out from the breather, which can mean that one or more pistons was fried & running at a lower CR, more than likely due to the fact that it was probably running lean. i get the jidgst of it, but i'm not going to even pretend i understand completely what is going on. so i need new pistons/rings probably, and he recommended new fuel injectors.
so what exactly is going on here? and anyone know what i will need and how this will be fixed? any help would be greatly appreciated.
i have a 2001 Acura Integra GSR with a DragIII turbo set up(everything else is stock), i had it installed at Signal Auto in Torrance, but have had nothing but problems afterwards (leaky exhaust manifold gasket, loose fuel lines spraying everywhere{sweet!}, and plenty of everything else)
Old Mar 20, 2002 | 11:03 PM
D-SPEED's Avatar
Default Re: piston fried (Ruckus138)
look into a quality fuel system like hondata, which you will need some bigger injectors for.
http://www.hondata.com
Old Mar 20, 2002 | 11:07 PM
sushibug's Avatar
Default Re: piston fried (D-SPEED)
smoking coming out means oil being burnt i think. which means the piston rings might be leaking and oil is coming from the block past the piston into the combustion chamber. one of the possibilities. i dont u burnt a piston, i melted some valves onto my head once though. that was fun
Old Mar 21, 2002 | 04:19 AM
SiR Kid's Avatar
New User
Default Re: piston fried (sushibug)
Piston might look like this, to a lesser degree!
Old Mar 21, 2002 | 05:37 AM
Doodoo's Avatar
Default Re: piston fried (SiR Kid)
!!! Mine looks like that!! Just not that bad....still holds compression too
Old Mar 21, 2002 | 08:51 AM
DIRep972's Avatar
Smarter than you
do a compression test, and leak down test.. see where u stand from there..
Old Mar 21, 2002 | 10:23 AM
Turbo EG6's Avatar
New User
Hey that looks familar
Old Mar 21, 2002 | 10:32 AM
The_Head's Avatar
Default Re: piston fried (Turbo EG6)
been there, done that
Old Mar 21, 2002 | 10:52 AM
turbopanda's Avatar
Default Re: piston fried (xThexHeadx)
ahh the memories of not using a standalone ECU..
(FYI, that is not a Honda piston, I use Toyota pistons in my D16Y8)
Old Mar 21, 2002 | 12:09 PM
PWRVTEC's Avatar
Default Re: piston fried (nathan's boosted civic)
And another piston to add to the mix.... SR20DET piston.
Old Mar 21, 2002 | 01:37 PM
turboex's Avatar
HOLLA!!! Welcome to the club. Time for new pistons. how about some 8to1 like me there great!
Old Mar 21, 2002 | 03:34 PM
SiR Kid's Avatar
New User
Default Re: piston fried (turboex)
Here's a better PIC of mine....
[Modified by SiR Kid, 6:34 PM 3/21/2002]
sasinorm01
Oct 16, 2011 01:48 PM
xcguyxc
Mar 17, 2005 04:50 PM
jetpilot
Jun 2, 2004 01:30 PM
navz121
Feb 11, 2004 11:30 AM
ricemaster (r)
Jun 3, 2003 09:19 PM
