Which Piston Compression HELP
Old Oct 9, 2006 | 12:10 PM
EM1OwnerSi's Avatar
Default Which Piston Compression HELP
Hey guys im about to build a full ls vtec turbo motor. the block will be sleeved to 84mm and i was wondering whats the best compression ratio for this? I know i should run low but what numbers. What pistons should i get. Im not worryed about money i want the best.
Old Oct 9, 2006 | 12:15 PM
Hondoctors's Avatar
The higher compression you run on a boosted motor, the more sensitive it will be to changing conditions. (outside temps, Intake air temps, timing, etc) You will make more power, with lower boost levels on a higher compression motor. It depends on how much power you're trying to make, usually daily driven cars should see between 9:1 and 10:1. I like CP and Wiseco pistons.
civic-r11
Mar 31, 2009 12:04 PM
Rooftop voter
Nov 2, 2008 10:01 AM
jdm2teg
Dec 14, 2005 01:41 PM
shortdahri
Mar 25, 2002 08:49 PM
