Piston Comparison, not a newb, need some advice
Old May 10, 2002 | 07:20 PM
1.8EG-T's Avatar
Default Piston Comparison, not a newb, need some advice
Comparing the wiesco with the Je(not srp). The over all quality,daily drivability, along with 12 pounds of boost, maybe a little more. Which would YOU prefer. And could you state reasons. JE's are the universal "built motor" piston,but cost a ton and weisco, other than endyn, I have not heward much about...sorry for ranting but thanks for your help.
Old May 10, 2002 | 11:08 PM
sweettooth's Avatar
Default Re: Piston Comparison, not a newb, need some advice (hybridrex)
je
Old May 10, 2002 | 11:49 PM
Sonny's Avatar
I did a lot of research on this and spoke to people at JE as well as Larry at Endyn. I do not regret my choice. Larry's business practices and past decisions have been under constant fire, but I don't think anyone can deny that when it comes to combustion technology, the man knows his $hit. He answered every question I had in levels of detail that I could not get from the other guys. For example, all D series engines have the same bore and stroke, but the layout of the DOHC D series engines (ZC/D16A1/A8/A9) combustion chamber is different. Larry knew the layout and details of every D series head as well as the advantages and disadvantages of each one and was able to make recommendations on squish clearance, milling/decking, and porting each configuration. My experience with Endyn, to date, has been exceptionally positive.
I looked at the JE piston for the ZC and basically looked like someone took a ZC piston and whacked the dome off. JE's rep for building high quality, high performing, super tough pistons is well deserved. However, in my particular case, I was looking for something specific and I got with the Rollerwaves.
If there is a good tuner out there that has been unhappy with Rollerwave pistons, I have yet to hear about him/her...and I talked to several before making my choice.
My 2 cents...
Sonny
Old May 11, 2002 | 07:22 AM
1.8EG-T's Avatar
Sorry, I should have stated that I will not buy pistons from ENdyn...these will be bought from a reputable dealer.
Old May 11, 2002 | 09:33 AM
MaxBoost's Avatar
New User
Give ross pistons a try, if not go JE. Wiseco are low-tech domestic pistons. The run sloppy clearances compared to JE, Arias, and Ross pistons, and they have a high Si content which makes it easy to believe that they might be weaker. Plus they are heavier than Ross or JE pistons. Just get a set of JE and sand down the tops. IB sells the pistons with the tops already sanded.
Old May 11, 2002 | 09:44 AM
2K_TEG's Avatar
Default Re: Piston Comparison, not a newb, need some advice (MaxBoost)
I got some 84mm JE's in the mail yesterday. After looking them over, I am completely impressed. Very nice quality. I ran some Arias in an Accord motor a few years back and they were also very nice. I do not think you can go wrong as long as you choose from JE, weisco, Ross or Arias. They all are good.
Old May 11, 2002 | 03:29 PM
1.8EG-T's Avatar
Default Re: Piston Comparison, not a newb, need some advice (2K_TEG)
THanks for the suggestions...anyone got any last words......
Old May 11, 2002 | 03:36 PM
SEFIxCivic's Avatar
is that what you read in a magazine??
[Modified by SEFI8LOxCivic, 12:38 AM 5/12/2002]
Old May 11, 2002 | 04:06 PM
gsr squirrel's Avatar
New User
i was quite sure that both JE and Wiseco use low silicon aluminum while the low compression SRP and Arias pistons use high silicon aluminum.
i plan on getting a set of 84mm wiseco for your information.
[Modified by gsr squirrel, 8:08 PM 5/11/2002]
Old May 11, 2002 | 04:21 PM
immortal's Avatar
Banned
Default Re: Piston Comparison, not a newb, need some advice (SEFI8LOxCivic)
Atually I also heard the clearances for wiseco's are all over the place, and it was from a very reputable company which I will not name here, but you've all heard of them and they do the best work at what they do.
Old May 11, 2002 | 05:16 PM
SEFIxCivic's Avatar
Default Re: Piston Comparison, not a newb, need some advice (immortal)
well from personal experience wiseco clearances are fine, and run significantly quieter than jes & arias.
Old May 11, 2002 | 07:02 PM
1.8EG-T's Avatar
Hmm...and it starts to get confusing.
Old May 11, 2002 | 07:14 PM
Sonny's Avatar
What is it that is confusing? I think the common consesus (based on actual measurements and use....not what my brother's uncle's dog said ) is that Wiseco, JE, and Arias pistons are all good pistons.
Sonny
Old May 11, 2002 | 07:44 PM
B20C5 Turbo's Avatar
New User
Default Re: Piston Comparison, not a newb, need some advice (Sonny)
Well, I have examined and used both JE/SRP and Weisco (ala Endyn) pistons. The Weisco pistons have more meat between the valve reliefs and top ring, which I equate with reliability under stress. The JE/SRP's absolutely require some touch up before use that needs to be done BEFORE weight balancing. If you want Weisco pistons, and refuse to deal with Endyn, throw me an e-mail. I will be glad to be of assistance.
Old May 11, 2002 | 08:06 PM
SEFIxCivic's Avatar
Default Re: Piston Comparison, not a newb, need some advice (B20C5 Turbo)
my thoughts exactly. the thin areas that make up the valve reliefs in arias and jes are definate weak spots. i have an arias piston cracked right at that spot. i've seen some custom jes that don't have that sort of problem, but the majority of pistons i see from other manufactures neglect that area, and that leaves me to think that they don't spend a lot of time/thought designing the piston surface.
Old May 13, 2002 | 06:43 AM
Dublocivic's Avatar
I ordered my pistons from Larry and got them in a few days.. Ive had nothing but good customer service from Endyn. Larry is always willing to help with any "too techy" questions that cannot be answered by most people. I fully agree with Sonny... The Wiseco piston is a great piece.. Ill be running them in my 5-600hp monster.
hybrid_vtec
Oct 22, 2005 05:01 PM
Quitripin
Aug 9, 2004 05:36 PM
hatchback19
Jan 31, 2004 01:50 PM
91hondacrx
Jun 17, 2003 08:13 PM
SSBP DC2
Feb 28, 2003 11:55 PM
