Piston Coating
Old Oct 3, 2012 | 08:13 AM
bigG's Avatar
Default Piston Coating
Who is everyone going to and what type of coating are they using?
Old Oct 3, 2012 | 08:37 AM
Muckman's Avatar
Moderator in Chief
Default Re: Piston Coating
Coating on the top or sides?
Old Oct 3, 2012 | 11:15 AM
Ben Huynh's Avatar
Save your money.
Old Oct 3, 2012 | 11:33 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
I used swaintech for me NA engine. Two coatings, ceramic on the top and some sort of Teflon on skirts. It wasn't all that expensive either.
Old Oct 3, 2012 | 11:51 AM
Ben Huynh's Avatar
Coatings are counter productive. Depending on the coating, some trap heat and most eventually wear off. There are no upsides. I wouldn't recommend them at any cost but we still have customers demanding it.
Old Oct 3, 2012 | 11:56 AM
TKERacer619's Avatar
I have used swain in the past for top and skirt coating.
Wiseco pistons come from the factory with a skirt coating.
Old Oct 3, 2012 | 12:07 PM
vtechjunkie's Avatar
I just saw on Facebook, that Bisi was talking about all the advantages of coatings. That "all engines, fi or na, can benefit from ceramic coatings". Am I mistaken?
Old Oct 3, 2012 | 12:16 PM
Muckman's Avatar
Moderator in Chief
Ive always used ceramic coating on my pistons for extra insurance against heat.
Old Oct 3, 2012 | 12:27 PM
rudebwoy's Avatar
I was gonna quote you before you reply on this.
I used Wiseco coated pistons before, the coating got erased with the oil I used during installation. I think its a waste of money.... also if it did serve a purpose why did they put the W in the coating, leaving the W uncoated?
Ben Huynh's Avatar
People will make recommendations for products that will help their bottom line. I don't do that and people seem to appreciate the honesty. I've turned customers away from countless products they don't need over the years and I've been doing this since 1997. Is it the smart thing to do? Maybe not, but I think it comes around full circle.
IMO, coated pistons offer no upsides whatsoever. Coated skirts do but are limited to a reduction in friction.
Old Oct 3, 2012 | 01:14 PM
bigG's Avatar
i have head both sides and would like to test it for myself is all but not sure who to go to and i want the top and skirts coated
Old Oct 3, 2012 | 01:17 PM
Muckman's Avatar
Moderator in Chief
Swaintech is the best in the industry. They are also local to me
Old Oct 9, 2012 | 12:53 PM
SkirtChaser's Avatar
The vast majority of coatings are designed for either scuff resistance or friction reduction. Check out Abradable Powder Coating; it's been around since 2000 and is the only coating specifically designed for clearance control. It is fuzzy as sprayed. You build it tight (too tight). During initial operation (break-in period), each piston laps itself to fit each bore. When there is just enough room for the perfect oil film to form, the mating surfaces can no longer touch and the wear stops. Now you have the lowest friction oil film and tightest possible clearance for each piston in each bore. Pistons rock less so the rings stay square to the bore to seal better and minimize wear.
Muckman
Oct 10, 2011 02:54 PM
JDM-EJ698
Apr 23, 2009 06:29 PM
sgT
Oct 26, 2002 09:39 AM
