Can i turbo my Sohc Zc on a $1500 budget?
Can i turbo my Zc with $1500? If so what would my shopping list consist of? this is my first time building a motor. How much hp can i expect if its possible? This is my daily and bone stock if that helps at all...
Re: Can i turbo my Sohc Zc on a $1500 budget?
If no then how much will i need to have to have a reasonably decent turbo'd daily. Im not trying to sound like a complete rookie. but i do need some help. Thanks
The problem is that ALL the information you need is readily available. All you have to do is 1.Read the FAQs 2.Search through Google. Don't expect to be spoon fed because it won't happen. We ALL were in your position once, and most of us never got spoon fed.
DO IT ON ALL FOURS
Hello. Boogie-Woogie!!! Did that scare you away yet? No? Then ACTUALLY TRY SEARCHING... this EXACTsame question gets asked around 5 times a week. Some take the time to answer them again and again, but we all get burned out.
Putting a turbo kit on a vehicle is not "building an engine".
$1,500 budget won't even get you half way there even with a junk *** eBay kit.
Save your pennies or sell your car and buy something else.
Also, pull up your pants son, it just looks silly.
If you loved me, you'd all sell me your magic cards to me today
You can make a turbo set-up from anywhere between about $150 and $15,000 without getting ridiculous.
I'm pretty sure that 90% of H-T cannot do basic math.
Vitara/rods/headstuds = ~650. I can see putting together a turbo setup for 850, if you know what you're doing and know what you're looking for and don't mind being cheap...
...clutch, Injectors, ECU+tuning for junior here? There is easily nearly a grand right there.
2500 is doable, 1500 is simply not going to happen.
Yup but I wouldn't recommend it if you need the car to go to work.
You are better off saving the cash and doing it right.
