Piecing a Turbo Kit together?
http://www.cse.uconn.edu/~yele....html
here's a good start...search on the parts
then u'll end up looking for injectors, better fuel pump, spark plugs...
heres what youll need
turbo(selection depends on power desired and purpose of car)
intercooler (depends on power)
manifold(ac compatible or not, cast iron or Steel, top mounts vs bottom mount)
downpipe
oil lines and fittings
coolant lines(if turbo supports ie gt series turbos)
piping, couplers, and clamps
wastegate(size depends on power)
vacuum lines
blow off valve
injectors(size depends on power)
fuel pump(walbro 255 should support most goals)
engine management system, uberdata hondata, neptune, aem ems, crome, motec, fast, tons more
downpipe
vacuum lines
blow off valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrdthry911 »</TD></TR><TR><TD CLASS="quote">heres what youll need
downpipe
vacuum lines
blow off valve
engine management system, uberdata hondata, neptune, aem ems, crome, motec, fast, tons more</TD></TR></TABLE>
yeah what he said. also a bottom end build would be nice depending on your power goal.
downpipe
vacuum lines
blow off valve
Terrible One
Dec 21, 2006 04:45 PM
a1320addict
Mar 10, 2005 09:38 PM
60-1teg
Oct 29, 2003 05:53 PM
