phx42
Old Dec 19, 2005 | 08:29 AM
turboedc2's Avatar
Default phx42
has anybody used the new turbo from cheapturbo phx42
Old Dec 19, 2005 | 11:51 AM
HybridKOOP's Avatar
Default Re: phx42 (turboedc2)
I'm using it, but the car won't be dyno'd until Spring.
Old Dec 19, 2005 | 12:42 PM
PeakBoost's Avatar
B*A*N*N*E*D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedc2 &raquo;</TD></TR><TR><TD CLASS="quote">has anybody used the new turbo from cheapturbo phx42 </TD></TR></TABLE>
Phoenix Turbo
yeah, seems like everyone that we've built them for won't have any results till at least feb.
im going to be running one on the PeakBoost EVO mid Jan. ill make sure to post results on H-T too, if you'd like. after the tilton clutch goes in, we'll be swapping out the BBTO4R T3p for a PHX42 T3p
Ron @ IPS (HT name= EDO) will be using one on their new 2.7L K-series very soon. im sure you will see these results
feel free to PM me with any questions
Ken Peak
Old Dec 19, 2005 | 01:30 PM
vaporboy12's Avatar
Default Re: phx42 (PhoenixTurbo.com)
ill test one out for you haha
Old Dec 20, 2005 | 07:49 AM
turboedc2's Avatar
Default Re: phx42 (vaporboy12)
cant wait to see results cuz am debating on which one to buy phx42 t3 or t3\t67 is been the biggest the decision for me.
Old Dec 20, 2005 | 07:51 AM
tony1's Avatar
I tested the phx47 a while back, which was the gt47 compressor with a gt30 turbine wheel. Didn't work out so well...
Old Dec 20, 2005 | 07:55 AM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: phx42 (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I tested the phx47 a while back, which was the gt47 compressor with a gt30 turbine wheel. Didn't work out so well...</TD></TR></TABLE>
ahahhaahaa
Old Dec 20, 2005 | 08:06 AM
tony1's Avatar
It's ok Ken, i'm not mad. I mean we tried something diff. and it didn't work, no biggie.
Old Dec 20, 2005 | 08:45 AM
PeakBoost's Avatar
B*A*N*N*E*D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">It's ok Ken, i'm not mad. I mean we tried something diff. and it didn't work, no biggie. </TD></TR></TABLE>
**** happens
Old Dec 20, 2005 | 08:51 AM
tony1's Avatar
ok, before anyone thinks we're both idiots for trying that, i'm kidding. lol
Old Dec 20, 2005 | 09:13 AM
rudebwoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurbo.com &raquo;</TD></TR><TR><TD CLASS="quote">
Phoenix Turbo
Ken Peak
so you aint cheap anymore? lol
Old Dec 20, 2005 | 09:31 AM
edo's Avatar
edo
Default Re: phx42 (rudebwoy)
Yes, Ken took care of us with a PHX42S with a non-divided .96 AR hotside, which is super nice. We have two turbo dev motors, so we needed another snail. Phoenix Turbo sent us the GT4294R as well. Here's how I think it's going to play out:
PHX42S - 2140cc, 9:1cr - 89mm bore x 86mm stroke, K24 block
GT4294R - 2525cc, 10.5:1cr - 87.5mm bore x 105mm stroke, K24 block
We're trying to get the PHX42S up and running in the upcoming weeks. The motor is built and in the car, just need to fab the IC and downpipe.
-Ron
Modified by edo at 10:51 AM 12/20/2005
Old Dec 20, 2005 | 10:19 AM
EF9ZC's Avatar
Hurry up ron lets see some dynos...
Old Dec 20, 2005 | 10:53 AM
WHTZ's Avatar
Default Re: (EF9ZC)
What's the weight on the Phx42?
Old Dec 27, 2005 | 12:15 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (WHTZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHTZ &raquo;</TD></TR><TR><TD CLASS="quote">What's the weight on the Phx42?</TD></TR></TABLE>
only about 20lbs
Old Dec 27, 2005 | 12:34 PM
*Boostwerks*'s Avatar
I'm sure this will be a VERY popular turbo in SPFWD, and T4 in 2006. can't wait to see it...
Old Dec 27, 2005 | 12:58 PM
cuin9sec
Guest
Posts: n/a
just fork out the extra dough and buy a 42r...
Old Dec 27, 2005 | 01:40 PM
99_GS-T's Avatar
I always thought it was good business to test a product before releasing it?
I'd be REALLY hesitant in using a P-trim with the GT42R compressor wheel.
Ah... Are you guys modifying the boreless GT42R compressor wheel to work with a conventional thru shaft too??? Or is that something that Garrett does and sends out to you?
Old Dec 27, 2005 | 01:50 PM
uglyasscivic's Avatar
Default Re: (gt42r_civic)
The only thing I dont like about the 42R is the overall size. The only way I see the phx42 hanging with the 42R is if a straight 42R or GTS exhaust wheel is used to keep exhaust backpressure down during cam overlap. If someone tries a P-trim or even the pos GTQ wheel at high pressure ratios there will be some pissed people out there.
Old Dec 27, 2005 | 02:00 PM
99_GS-T's Avatar
Default Re: (uglyasscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscivic &raquo;</TD></TR><TR><TD CLASS="quote">If someone tries a P-trim or even the pos GTQ wheel at high pressure ratios there will be some pissed people out there.</TD></TR></TABLE>
The P-trim/GT42R sounds good on paper...
Well, not really, once you start thinking about size difference and airflow potential of the P-trim to the GT42R turbine wheel. Hindsight is 20-20 though.
I could be wrong, but I think the GTS turbine wheel still an awesome cut down GT42R turbine wheel... Better buy them in bulk so you can swap them at the track when they roll out the tail pipe.
Old Dec 27, 2005 | 02:03 PM
Default Re: (99_GS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_GS-T &raquo;</TD></TR><TR><TD CLASS="quote">
I could be wrong, but I think the GTS turbine wheel still an awesome cut down GT42R turbine wheel... Better buy them in bulk so you can swap them at the track when they roll out the tail pipe. </TD></TR></TABLE>
Still...
This is exactly what people said of the 67 with the Stage 5wheel. It has been shown to be a fairly potent combination. Only time will tell.
Old Dec 27, 2005 | 02:34 PM
Boostfed's Avatar
New User
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
Still...
This is exactly what people said of the 67 with the Stage 5wheel. It has been shown to be a fairly potent combination. Only time will tell. </TD></TR></TABLE>
Yeah things that don't work on paper ie compressor maps seam to work in the real world. If we used compressor maps then all Hondas would be on a straight T3 turbo. We shall see when these get tested. I am interested.
I would think GTS wheels flying out the exhaust pipe would be just an added benefit at no etxra charge!
Edit:Also Garrett is GREAT and they KNOW what works since they R&D everything but people seem to make variations on their turbos and they work, maybe not IDEAL but they work.
Old Dec 27, 2005 | 02:38 PM
tony1's Avatar
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote"> If we used compressor maps then all Hondas would be on a straight T3 turbo. </TD></TR></TABLE>
How do you figure?
Old Dec 27, 2005 | 02:48 PM
Boostfed's Avatar
New User
Default Re: (tony1)
How do you figure?</TD></TR></TABLE>
NM me talking out of my ***, I was thinking about my old Turbnoetics catalogue that had engine sizes listed and showed our motors should be on a T3 turbo lol.
Edit:Now that I check out Turbonetics new site they do have engine sizes updated and power goals, 700hp they recommend a T72 Ptrim in a .58 A/R and then 800hp T72 Q trim .58 A/R , turbine housings seem really small for these
Old Dec 27, 2005 | 06:33 PM
99_GS-T's Avatar
Time will tell.
I would just hold on to your money for some results to come back before you buy into the idea though. Just call it a hunch.
