performance radiators???
Old Apr 18, 2002 | 02:30 PM
morepoop4u's Avatar
Default performance radiators???
where can i get one cheap and have it delivered fast. my shop needs a new radiator for my car since i got into an accident, so i decided to go with an aftermarket one. the thing is that i need it deliverd fast or i'll just stick with a stock one. also do i just need to get a thinner radiator fan or an AC fan too and what are the prices on that.
Old Apr 18, 2002 | 04:35 PM
therealnapster's Avatar
New User
Default Re: performance radiators??? (morepoop4u)
http://www.absoluteradiator.com has the cheapest prices on both fluidyne and koyo's I've ever seen $290 or so for civics, it came quickly too. I orderd this last summer they're dope too I can blow cold ac/ and still run boost.
Old Apr 18, 2002 | 05:20 PM
morepoop4u's Avatar
Default Re: performance radiators??? (sohckid)
thanx
Old Apr 18, 2002 | 05:45 PM
Geovannie's Avatar
Can somebody post the dimensions of some stock civic radiators for the different generations.
Old Apr 18, 2002 | 06:09 PM
Etylorcen's Avatar
Default Re: performance radiators??? (Geovannie)
The civic one is puny!
Old Apr 18, 2002 | 06:29 PM
echo999's Avatar
New User
Default Re: performance radiators??? (Etylorcen)
If you have a 98+ GSR, don't even think about running the stock fans if you
go with a Fluidyne radiator. I had temporarily hook up the A/C fan in the
radiator fan spot, and run with no A/C fan. I only have around 2 1/2 clearance
between the turbo and the radiator.. Definitely will have to go with a SPAL fan
(2.05") instead of a FAL or Fluidyne Slimline..
Old Apr 18, 2002 | 07:46 PM
jamal-188's Avatar
Default Re: performance radiators??? (echo999)
So,l I should buy a spal fan? Which one will I need for a 01 GSR? Where can I get one?
Old Apr 18, 2002 | 09:38 PM
dbman96's Avatar
New User
Default Re: performance radiators??? (jamal-188)
If you need it fast, be sure to get Absolute Radiator to ship by Fedex EXPRESS - I got it shipped Fedex Ground and it took forever.
Old Apr 19, 2002 | 06:35 AM
echo999's Avatar
New User
I'm thinking you'll need a 10".. make sure it's the 2.05" max depth.
I think 12" would be overkill for your A/C. but definitely get the biggest
you think will fit. (I think 12 will fit.. but I haven't done this yet).
I've thought of mounting the fans as a pusher, but there just isn't enough clearance between the intercooler and AC condensor. Also, puller is much
more efficient (so I hear).
BongoBennie
Jan 10, 2017 06:29 PM
almostboostedgsr
Jul 26, 2007 10:40 PM
Tuesdaynightfever
Apr 4, 2005 12:30 PM
EU BATT
Nov 22, 2002 08:23 PM
morepoop4u
Apr 18, 2002 05:22 PM
