The Perfect Turbo GSR Build?
Old 05-04-2014, 01:08 AM
DC2GSR808's Avatar
Default The Perfect Turbo GSR Build?
Im wondering what is the best everything for the B18C1 motor. From the best turbo to the best exhaust, best air filter, and best internals. Im thinking about going 8.3 Compression Ratio. 300 - 400 hp street car.
Old 05-04-2014, 01:55 AM
turbomaniac's Avatar
Default Re: The Perfect Turbo GSR Build?
cp pistons and eagle rods are good value for money internals for 400hp.
a GTX3067R is also a good turbo for your application
as for exhasut a 3' is a good choice.
tial 38 is a good option for that power.
8.3 is too low CR, i would have gone for 9 -10
walbro 255 pump
stock cams and head are ok for that power you want..
and of course tuned ecu with at least 600cc injectors
Old 05-04-2014, 02:15 AM
I never narc'd on nobody!
NotARaCist's Avatar
There is no such thing as "best for everything". A best for drag turbo will be too big for road race courses, and WAY too big for autocross. 8.3 CR is way too low - stick with 10:1, if not a little higher. For 400, BARE minimum would be ID725's, but you would be better served with ID1000's.
Basically, you need to decide exactly what you want out of your car if you expect to get any real advice. There are no "stretchy pants" in the FI world.
Old 05-04-2014, 02:30 AM
DC2GSR808's Avatar
walbro 255 pump
What is the lowest CR do you think is good?
Old 05-04-2014, 02:33 AM
DC2GSR808's Avatar
ID725? ID1000? Sorry im still new to boosting and compression ratios and stuff like that.
Old 05-04-2014, 03:00 AM
NotARaCist's Avatar
Why are you so insistent on lowering your compression ratio?
ID's are injectors, specifically injectors made by Injector Dynamics. One of the best options on the market right now. ID725's are 725cc/min injectors, ID1000's are 1000cc/min injectors.
Old 05-04-2014, 03:26 AM
DC2GSR808's Avatar
My Friend told me to go 9.0:1 CR with GTX3071R
Old 05-04-2014, 05:08 AM
9:1 is a very safe CR with no too menu hp loss
Old 05-04-2014, 05:35 AM
NotARaCist's Avatar
A 300 WHP goal and 400 WHP goal will both use different turbos, and once again, for different purposes. You're still trying to skirt around what you plan on using the car for. if you can't tell us that, we can't tell you anything useful.
Old 05-04-2014, 06:02 AM
$MIKE$'s Avatar
Over night parts form summit.
But serious 8.3cr? Do some research this isn't 1998, do e85 and some 10.5:1
600cc are really small get some id1000 for pump or 2000 for e85.
Also hope you got a big budget
"The best" parts aren't cheap
Old 05-04-2014, 06:35 AM
bungalo101's Avatar
Looks like you need to do some more research. Read the FAQ, read some GSR build threads, check out some dyno sheets to see what type of power curves are being made with different turbos and find something you like.
Post your budget as well if you want more than just generic responses.
Old 05-04-2014, 11:05 PM
DC2GSR808's Avatar
What are all the things i could change to go boost? I know i could change the piston, rod, valve, valve springs, bearings, and flywheel, but idk if its necessary to change the camshaft or crankshaft.
Old 05-04-2014, 11:38 PM
COM2's Avatar
For your power goals, a simple rod and piston combo will be fine. Keep it simple.
Old 05-04-2014, 11:43 PM
i agree
Old 05-04-2014, 11:57 PM
DC2GSR808's Avatar
i agree
So cp pistons and eagle rod on a gtx3071r good enough?
Old 05-05-2014, 03:20 AM
NotARaCist's Avatar
You're STILL skipping over the most important question. Answer it already, it's not that hard.
Old 05-05-2014, 03:29 AM
Ferio Wdm Edition
ferio-ichi3's Avatar
^^^lol
Old 05-05-2014, 09:05 AM
DC2GSR808's Avatar
Huh? What was the question?
Old 05-05-2014, 09:14 AM
Moderator
TheShodan's Avatar
Old 05-05-2014, 11:01 AM
Man U FTW
Schister66's Avatar
What do you want out of the setup? What are your goals? What is the purpose/use for the setup/car? What is your budget?
Before you get wrapped up in the parts and details, you need to answer these questions....otherwise you're going to get a bunch of irrelevant, inconsistent opinions. Everyone has their idea of what is "best" but it may not be what you're looking for
Old 05-05-2014, 11:41 AM
Moderator
TheShodan's Avatar
A more elaborate way of asking this.
Old 05-05-2014, 12:08 PM
Man U FTW
Schister66's Avatar
Yes, it was a bit repetitive, but i wanted to avoid this \/\/
Old 05-05-2014, 05:08 PM
Who is Mr Robot?
wantboost's Avatar
There is no such thing as perfect.
For every power goal and purpose of the car a different part for a different system is required. Each part has it's pros and cons.
for example, a turbo for an 800hp car isn't going to be the proper unit for a 400hp motor. different intake manifolds for different power bands and purposes, different cam shaft profiles, different turbo manifolds with different runner lengths and diameters, etc.
different connecting rod materials and designs, different compression ratios, etc.
you need to decide on a concrete power goal and the purpose of the car and then start choosing parts around that goal and purpose.
however if you don't how how changing each part will effect the overall system I suggest you research heavily before purchasing anything
Old 05-05-2014, 05:30 PM
NotARaCist's Avatar
Originally Posted by wantboost
Tfor example, a turbo for an 800hp car isn't going to be the proper unit for a 400hp motor. different intake manifolds for different power bands and purposes, different cam shaft profiles, different turbo manifolds with different runner lengths and diameters, etc.
And to further expound on that, a proper turbo for a drag-oriented car will be different than a proper turbo for a road course car, and still different again from a proper turbo for an autocross car. There are WAY too many options out there, and WAY too many uses to have a "perfect" turbo.
Old 05-07-2014, 09:36 PM
DC2GSR808's Avatar
A street car that I could take to drags and run around 12s. There is no budget for this build. I was thinking 400 hp with a good tune. But I wanted to see what kind parts you guys would offer that are great.
Quick Reply: The Perfect Turbo GSR Build?
