peak and hold or saturated injectors for jrsc setup?
i don't really know a whole lot about the different types of injectors, so i was wondering if someone could tell me the difference between them and which would be better for a jrsc setup. thanx
Re: peak and hold or saturated injectors for jrsc setup? (98civicguy)
Here is a link to explain:
http://www.msdignition.com/fuel_3.htm
If youre running the GSR motor in your sig, you will use saturated injectors. You can still use peak & hold injectors (ie DSM 450's), but you would have to wire 10 watt 10 ohm inline resistors or a resistor box from an earlier CRX/Accord/Integra etc. If youre buying them new from RC or something, get saturated, as B18C1's run saturated injectors from the factory.
b16bri
09-05-2010 02:53 PM
Schister66
04-26-2006 08:36 AM
boost_is_best
02-28-2006 03:45 PM
