Peak & Hold or Saturated
Old Mar 5, 2005 | 10:49 PM
FullRaceTurboSi's Avatar
Default Peak & Hold or Saturated
I was wondering what was better to use on a GSR turbo motor with Hondata. I want to be around 500hp.
Old Mar 5, 2005 | 10:52 PM
T4eg's Avatar
Default Re: Peak & Hold or Saturated (FullRaceTurboSi)
peak and hold require a resister box
saturated dont
Ur stock injectors are saturated. I am using 1000cc peak and holds and would also recommend them for your power goals
Chris
Old Mar 5, 2005 | 11:05 PM
What makes Peak & Hold better? I see alot of turbo cars have them so i was just wondering. Thanks
Old Mar 5, 2005 | 11:07 PM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullRaceTurboSi &raquo;</TD></TR><TR><TD CLASS="quote">What makes Peak & Hold better? I see alot of turbo cars have them so i was just wondering. Thanks</TD></TR></TABLE>
I can't speak of their physical qualities, but I know saturated injectors of the larger kind tend to get ridiculously expensive vs. peak/hold units.. food for thought.
Old Mar 5, 2005 | 11:59 PM
s2kdre's Avatar
Default Re: Peak & Hold or Saturated (VTC_ohgodnotagain_CiViC)
nothin makes them better its just usually anything over 880cc are peak and hold.
Old Mar 6, 2005 | 07:26 PM
nojoke's Avatar
Default Re: Peak & Hold or Saturated (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">nothin makes them better its just usually anything over 880cc are peak and hold.</TD></TR></TABLE>
That "nothing" that makes them better is the ability to open up faster relative to a saturated injector of the same size. Once you get into really high horsepower, i.e. 400+hp, peak and hold's are superior.
Old Mar 6, 2005 | 07:37 PM
Mase's Avatar
Default Re: Peak & Hold or Saturated (nojoke)
resistor boxes are band aid fixes. the drivers in the ecu can not support the peak and hold injectors and adding a resistor box is not the correct solution, but a mere easy solution.
peak and hold injectors combined with peak and hold injector drivers are best (drivers found on motec, autronic and other high end engine management systems)
keep a look out, you will soon see peak and hold injector drivers appearing soon.
Old Mar 7, 2005 | 06:09 AM
BlueShadow's Avatar
check out this thread
https://honda-tech.com/zerothread?id=1126948
Old Mar 7, 2005 | 11:05 AM
RyanEJ8's Avatar
Default Re: Peak & Hold or Saturated (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
keep a look out, you will soon see peak and hold injector drivers appearing soon. </TD></TR></TABLE>
May I ask, in what engine management?
Old Mar 7, 2005 | 11:07 AM
Mase's Avatar
Default Re: Peak & Hold or Saturated (RyanCivic2000)
you can add it to your honda ecu's and aem ems, etc.... it will be wired in seperate
Old Mar 7, 2005 | 11:15 AM
JDogg's Avatar
aem has a seperate peak/hold injector driver
Old Mar 7, 2005 | 11:17 AM
b18bturbo's Avatar
Default Re: Peak & Hold or Saturated (JDogg)
is it like this mase.
http://www.acceleronics.com/versafueler.htm
Acceleronics VersaFuelerTM (US Patent 6836721) simply splices in between your current ECU and the big honkin' injectors that your monster motor needs. Splice it in, hook it up to switched 12-volts and ground, and you're on your way to the races.
The VersaFuelerTM provides separate "peak and hold" logic circuits for each injector. The "peak" supplies up to 4 amps to snap big injectors open quickly, something your ECU cannot do. Once the injector is open, the "hold" turns down the current to prevent the injector from overheating.
Your ECU will never know that it's running the Acceleronics VersaFuelerTM instead of the injectors. The VersaFuelerTM will not cause your engine control computer to "throw a code", or turn on the check engine light, or do anything else that would be annoying.
The VersaFueler TM comes with everything you need for installation. The locking connectors are dustproof and waterproof. Inside the anodized aluminum enclosure, all circuits are encapsulated to make them resistant to moisture, dust and vibration. The Acceleronics VersaFueler TM is designed to provide years of trouble-free service.
Old Mar 7, 2005 | 11:24 AM
Mase's Avatar
yes they are probably all very similar, but those are probably twice as much as the one im talking about....
Old Mar 7, 2005 | 11:30 AM
b18bturbo's Avatar
yeah if its under 150 most people will buy them up definitely if they do what they are suppose to will it be able to control 8 injectors or just 4
Old Mar 7, 2005 | 11:31 AM
JDogg's Avatar
Default Re: Peak & Hold or Saturated (b18bturbo)
the aem driver has 10 channels
99_red_si
Mar 1, 2008 09:14 PM
chieu
Jul 3, 2007 09:18 AM
92redhatch
Dec 7, 2006 05:46 AM
Hype__R
Jul 24, 2004 02:45 PM
nuro
May 5, 2004 03:51 PM
